Sponsored by: CARiD
13B Bridge-port questions
Old Jun 25, 2007 | 01:19 PM
666cody666's Avatar
I would like to know what is need for doing a bridge-port, like what motor is better for doing this, what type of hardend gears i need, carb or fuel inj, dizzy, seals or anythign else I forgot. I want to make a list of what i need before I go do this.
Old Jun 25, 2007 | 02:01 PM
PinkRacer's Avatar
Licensed Zip Tie Mechanic
Well we have a bridgeport in our race car and here's what I know of that's in there:
NA 13b with Weber 45DCOE carb and racing beat intake manifold piece, and distributor and coils from a 81-85 carbed rx7. This is in a race car and is very aggressively ported, and it hates to idle, or run at a constant throttle. It was built on an engine dyno and makes 285hp. Hope this helps a bit!
Old Jun 25, 2007 | 03:30 PM
rotaryengineering's Avatar
Recommendation
Unless your car is a full race car a well built 13B street port high compression motor would be a better setup. Bridgeport/P-Port are good for off-road use, but the street-port has more useable power without all the nonsense.
good luck
Old Jun 26, 2007 | 10:16 PM
diabolical1's Avatar
sounds like you have a lot of reading to do there. at any rate to even try to answer some of your questions you need to say what the ultimate setup will be - basically, are you thinking of a turbo or not? that will dictate which apex seals you need and to some degree, which block you need to start with.
i'll assume since you asked about which engine that you don't currently have 13B. if that's not the case, then just use what you have. you don't learn how to swim by jumping into the middle of an ocean.
the other stuff you mentioned, like fuel control and ignition, are TOTALLY up to you and the resources available to you. make a solid, realistic plan.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Nosferatu
Sep 5, 2015 02:13 PM
tonka_1956
Sep 2, 2015 05:55 PM
