Oh this sucks, this sucks so bad
Old Mar 30, 2002 | 09:26 PM
JumpyRoo's Avatar
So I spend two hours under my car today removing my starter. Finally, albeit against the Haynes directions, I have the starter removed but hanging by the power wire. This is a 12mm bolt that is strapped onto the two screws of the solenoid. I can turn this bolt for fifteen minutes and it won't move up or down the screw. It was loose to begin with, too. How on earth do you guys get a stripped bolt off a screw? I tried wedging it with a knife, fingering it, wrenches, ratches...
Old Mar 30, 2002 | 09:34 PM
MadMaxine's Avatar
Did you try a smalled wratchet size? 11mm or 10mm?
Old Mar 30, 2002 | 09:53 PM
JumpyRoo's Avatar
Yeah, but er, I gave up on it. I'm nineteen, getting old. My left arm can't take that kind of anglin' at that cold, cold temprature. (In the thirties today). Try it again tomorrow, though. Nice to know I'm doing what I can.
Or I'll just snip the O terminal from the power wire and crimp a new one on for the next starter.
Old Mar 30, 2002 | 09:56 PM
listen if you can get out just cut it or drill it out and replaceit for a new one
Old Mar 30, 2002 | 10:21 PM
Liquid Anarchy's Avatar
We come with the Hardcore
That or just get a helluva grip on it with a set of vice-grips. Always works for me.
Old Mar 30, 2002 | 10:44 PM
Felix Wankel's Avatar
Super Newbie
Is the hex of the nut stripped, or the threads on the starter?
Old Mar 31, 2002 | 12:06 AM
JumpyRoo's Avatar
The threads are what's stripped inside the nut. It makes me so mad
Old Mar 31, 2002 | 06:09 AM
ZombeGTA's Avatar
Well, what you need to do is try to stick a flat head screw driver underneath the nut and use a wrench to turn the nut and pry it to a still useable thread so it will start backing off. I know because just a few hours ago I was taking my starter off and had almost the same problem, but I disconected the long bolt first and then the stud second. The starter then slipped off of the long bolt and hit me in the forehead.
Learn from the mistakes of others.
Old Mar 31, 2002 | 10:36 AM
Aaron Cake's Avatar
Engine, Not Motor
Use a nut splitter to split the nut in half.
Old Mar 31, 2002 | 11:57 AM
JumpyRoo's Avatar
I'm going to snip right above the electrical terminal and install a new terminal. Only problem here is that the teriminal looks like it's shaped to fit the starter so it can't move around.
Oh yeah, and should/can I ground the starter?
Old Mar 31, 2002 | 01:27 PM
RETed's Avatar
The starter grounds through it's housing.&nbsp Just make sure it's bolted on tight on the engine when you put it back.
-Ted
Old Mar 31, 2002 | 02:38 PM
JumpyRoo's Avatar
That's what I figured. I have a wild and crazy idea for the starter that I will start a new thread for in a moment, then I will post the redirect in this thread.
Old Mar 31, 2002 | 02:42 PM
JumpyRoo's Avatar
Here's the new thread:
https://www.rx7club.com/forum/showth...threadid=66660
Old Apr 1, 2002 | 12:46 AM
JumpyRoo's Avatar
No, wait. Project's finished now. Car's started and everything.
Old Apr 1, 2002 | 12:50 AM
rico05's Avatar
WTB S5 N/A FC
So it worked? Glad to hear it!!
squirrels
Sep 1, 2024 09:52 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
