Megasquirt Tach stuff, and Trailing not firing at <700 rpm
Old Jun 20, 2007 | 11:17 AM
toplessFC3Sman's Avatar
Ok, I know the code turns off the trailing spark below 700 rpm, I was just wondering why, and what I can do to get it to work at those speeds. Also, the stock tach is reading about 200 rpm off from the MS output, is there an adjustment I can do to get the two to agree? Thanks
Old Jun 20, 2007 | 11:42 AM
T2GTUS's Avatar
I believe Ken can chime in on the why about the trailing. I had a tach "off" by almost 500 rpm ... there is an adjustment pot on the back of the stock tach ... pita to do though...
Old Jun 20, 2007 | 06:01 PM
muythaibxr's Avatar
MegaSquirt Mod
The code turns off trailing below 700 rpms, because spark below that point requires the use of the "low-speed" section of the code. Trailing was never implemented there since doing so is fairly complicated.
I had a code that fired trailing at the same time as leading, but it still had a small problem right when it goes from low-speed to high-speed.
If I have time I'll look at the code again to see if there's anything I can do to make it work.
Old Jun 21, 2007 | 06:50 AM
this is more of a convenience type thing, so we can know the engine speed when cranking etc, not really an operating or driving problem, so if you have a chance to look at it, then great, but if not, its no big deal either. Also, what program do you use to see/modify/write the code in? Thanks!
Old Jun 21, 2007 | 07:42 PM
muythaibxr's Avatar
MegaSquirt Mod
I use gvim as my editor.
Thor 18
Interior / Exterior / Audio
Sep 13, 2015 08:39 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
freq
Microtech
Aug 23, 2015 11:02 AM
freq
Aug 21, 2015 03:30 PM
