Fule line
Old Mar 30, 2002 | 05:27 AM
damn hippies
Fule line
does anyone have pics of were my fule pump and fule lines run, i have a 87TII, i belive the only thing wrong with my car is loss of fule pressure, it spits gass on the floor when starting but isnt reaching the engine
Old Mar 30, 2002 | 06:18 AM
NZConvertible's Avatar
I'm a boost creep...
That's not FUEL (note spelling! ) coming out of your tailpipes, it's just water vapour. It smells like fuel because cold-start mixtures are quite rich. How do you know you're losing fuel pressure? Have you checked it with a pressure gauge? Your question's a little vague, I'm not quite sure what the problem is. There are underside pics in the Haynes manual showing the fuel lines, and the fuel pump is in your fuel tank, accesible from a plate under the rear carpet.
Old Mar 30, 2002 | 07:42 AM
I wish I was driving!
Re: Fule line
Its pretty simple: 1 line runs off the pump to the fuel filter, then into the fuel rail.
The other line comes off the fuel rail and leads back into the tank.
There is another line, vacuum line, for your Gas vapour.
I am also confused about spitting of Fule [sic] onto the floor. Where is this happening?
I belive [sic] we need more info.
Sean Cathcart
Old Mar 30, 2002 | 09:43 PM
damn hippies
its not starting, it tunns and seems like it wants to go but dosnt get gas, it gives the same sound when i have it floored, think the gas line has a hole and losing pressure, does that sound like a bad though or something
Old Mar 30, 2002 | 09:51 PM
turbo dan's Avatar
It sounds like it's flooded. You need to try the unflooding treatment first. Try this link. I used to pull the egi fuse everytime until I put a switch in for the fuel pump.
http://rx7.freeservers.com/repairhb/help.htm
Old Mar 30, 2002 | 09:52 PM
No7Yet's Avatar
Uh. You sure it's not just flooded? That's what it sounds like to me. If you had a hole in your fuel line, you'd KNOW it.
Brandon
Old Mar 30, 2002 | 10:02 PM
damn hippies
alright, when my jumper pack chrges ill try some of yer ideas, i hope to god it is b/c i can hardly afford my damn insurance
BLK 93
11
Sep 9, 2015 10:56 AM
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
