Fusebox
Old Mar 30, 2002 | 12:18 AM
gonzz's Avatar
Fusebox
Has anyone ever changed one on a 80 Rx-7? Just wondering..
Old Mar 30, 2002 | 12:27 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Never changed one, but i had the whole entire electrical out of one I think its all intergrated with the harness... Why you want to change it?
Old Mar 30, 2002 | 11:40 AM
riffraff's Avatar
smog nazi destroyer
it is wired to the harness, but i know that it can be changed.
just donot forget were all the wires go to. i was actually thinking about changing it to a seond gen fuse box, just so i would be able to use those style fuses
Old Mar 30, 2002 | 09:55 PM
jeremy's Avatar
male stripper
i blew a fuse today while tearing the interior down. i know, forgot to undo the battery. anyway i laughed when we pulled out these glass fuses. i was thinking about switching it over to a rally style circuitbreaker set. wire flip switches to the center console.
Old Mar 30, 2002 | 09:58 PM
riffraff's Avatar
smog nazi destroyer
that would actually be cool.. get rid of fuese altogether
Old Mar 30, 2002 | 10:01 PM
Wattz's Avatar
Someone changed the fuse box in my car to a newer one. It uses those plastic fuses intsead of the glass tube ones.
Old Mar 30, 2002 | 10:03 PM
riffraff's Avatar
smog nazi destroyer
lucky you.. that is what i am going to do when ever i get around to it.. the second gens have those newer style fuses, so i figured i would switch to that.
Old Mar 30, 2002 | 10:44 PM
jeremy's Avatar
male stripper
it should be to hard as there aren't really that many.
Old Mar 30, 2002 | 10:46 PM
riffraff's Avatar
smog nazi destroyer
10. you probably would need a larger area than the fuse box, but go too.. let me know how it turns out
Old Mar 30, 2002 | 11:32 PM
DJ!
circuitbreaker setup is a good idea, but if i was going to change them i would go to glass fuses over the blade fuses. because the there is a lot more contact area on glass fuse than a blade fuse, so if the blade fuse got/have a dirty/bad connection there is more chance the circuit falure. if get my drift?
Old Mar 30, 2002 | 11:33 PM
riffraff's Avatar
smog nazi destroyer
i didnot realise that.. thanks for the info dj
Old Mar 30, 2002 | 11:44 PM
gonzz's Avatar
I was just wondering if anyone has changed one..
Old Mar 31, 2002 | 12:01 AM
riffraff's Avatar
smog nazi destroyer
do a search.. i think i remember something about someone doing it
The Shaolin
Sep 14, 2015 07:50 PM
uber-rx7
Sep 19, 2007 11:49 PM
gonzz
Apr 29, 2007 09:57 PM
Vin
Dec 16, 2005 12:36 PM
Atl_FB82
Dec 5, 2005 03:49 PM
