anyone running a totally stock ignition system?
Old Jun 13, 2007 | 11:17 PM
SAMIboarder's Avatar
JGTC every day.
I've never modified an ignition system at all. When should you think about getting your spark some help?
stock should be good for at least 10psi because that's stock boost pressure. what if you had a stock motor, except large street port and 3" exhaust, still on 10 psi (& some extra fuel) would you need more spark?
my gt35/large street port/3" exh. setup won't see more than 15psi. what do I need? thanks for any help or ideas.
Old Jun 13, 2007 | 11:42 PM
marcus219's Avatar
FC Mobsta
people go 400+ with stock ignition systems all the time. maybe msd for leadings and two for trailings if you got tha' cash.
Old Jun 14, 2007 | 12:17 AM
bigcox_03's Avatar
i had stock ignition with my setup for a while and after 1500 miles or so i start to get breakup at 15psi, but still fine at 10. hope that helps
Old Jun 14, 2007 | 12:26 AM
JGTC every day.
that's good to hear. thanks.
Old Jun 14, 2007 | 11:52 AM
lassen118's Avatar
the twin power always works nice if your looking to break 400
Old Jun 14, 2007 | 12:10 PM
FourtyOunce's Avatar
There are several factors that come into play - age/wear of stock coils, type of plugs used, etc. I personally have not upgraded my ignition system, other than relocating the coils and running race plugs. Current setup is: stock motor, 3 inch exhaust, GT35r single, FMIC, 1600cc secondaries, 550cc primaries, and PFC running 15-16 lbs on the street using 93 octane fuel.
Old Jun 14, 2007 | 12:11 PM
zinx's Avatar
_________________________
I have just a twin power and get no break-up at 21 psi even with the methanol.
Old Jun 14, 2007 | 01:06 PM
iceman4357's Avatar
20psi with alcohol/ 93 octane, twin power.
Old Jun 14, 2007 | 10:19 PM
mono4lamar's Avatar
In the burnout box...
Msd 8204 primary twin post coil, Msd 8207 blaster railing coils, and 3 mallory boxes... I'm waiting on the startup but I'm sure it will be sweet
I ran an msd 6a on the stock leading coil and liked it a lot. Adding in an ignition amp isn't that much work. Don't worry about modding the ignition system unless you currently have breakup or are going for 450+ IMO
Old Jun 14, 2007 | 10:21 PM
JGTC every day.
thanks for the info guys!
Old Jun 14, 2007 | 10:29 PM
sk8world's Avatar
Chasing numbers
didnt ground zero go 600+ with just a twin power a few years back?
Old Jun 15, 2007 | 07:40 AM
turbodrx7's Avatar
PURIST
I run a completely stock ignition on my FD. Coils have about 120K and i have no problems up to 14 psi. Once i hit 15 i start to get break up though. To be safe i run the car on 12psi on the street with no problems.
-Austin
Old Jun 15, 2007 | 04:24 PM
Busted7's Avatar
Will work for horsepower
A friend of mine runs 42 psi on his supra with just twin power and has no break up and i run 20 on my fd no problem.
Old Jun 20, 2007 | 09:58 AM
IRPerformance's Avatar
Sponsor
I've ran 20 psi on stock ignition with no break up. This was with a new oem leading coil and NGK 10.5 race plugs. What I don't understand is why certain tuners need an ignition upgrade for every car they tune past stock boost levels
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Joe428
16
Aug 19, 2015 06:24 PM
