Garrett GT-4082 ????
Old Jun 13, 2007 | 05:18 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
is this turbo too big?i have an s4 t2,street ported haltech 1600's etc i can get this turbo for a good deal is it worth it?
Old Jun 13, 2007 | 05:33 PM
Asleep's Avatar
7 Rx-7s since 1980
My Gt-4088r does not feel too big. The 82turbine wheel should contribute to faster spoolup then mine (full boost at 41xx rpm) but with less top end and more backpressure at higher rpm. What do you want to do with it? All around turbo would make sense. A strip-only, dyno-queen turbo might not be the right role.
Tony
Old Jun 13, 2007 | 06:42 PM
prjct87rx7's Avatar
yes all around perfromance is what i want about 400 reliable horses
Old Jun 13, 2007 | 07:20 PM
pacatkhp's Avatar
I have a GT4082 (.96 A/R) on my FD3 and can only agree with Asleep that it is a good all around turbo. I have 350RWHP at 14PSI on a very rich tune (10.x AFR) and full boost by 3,600rpm. Only issue I have with it is that I can't fit shortrunner manifolds due to its size. If you check out my signature, you can see my dyno run (prior to V-mount IC).
Hoon.
Old Jun 13, 2007 | 08:27 PM
Asleep's Avatar
7 Rx-7s since 1980
Hoon.
Hoon,
My Gt4088r came with a short runner manifold. I am getting ready to put it up for sale. I run a long/tuned runner setup now...for specific spool-up and high rpm/boost characteristics.
Tony
Old Jun 13, 2007 | 09:26 PM
Old Slow Coach's Avatar
Front Range Express
http://www.exileturbo.com/images/pdf/GT4082.pdf
^Here are the specs on it. I would say it is not too big for 400hp. Sure, you could reach 400 hp with a slightly smaller turbo, but let's not lose perspective. If you can get a real good deal on it, I would jump on it .
Old Jun 13, 2007 | 09:30 PM
prjct87rx7's Avatar
yea i have a buddy who is selling one brand new for 600.00. cause he needs to finish his car,and decided to go n/a
Old Jun 14, 2007 | 12:46 AM
DrewS2k's Avatar
v8 destroyer
mine should be ready soon theres another guy on herre who got 360 to the wheel at 12psi with a conservative tune and he said it spooled great forgot his name though oorx7 or somthing like that
Old Jun 15, 2007 | 01:53 AM
nyt's Avatar
nyt
gt4082 is a tiny turbo. the compressor wheel is only 59mm. its close to a 60-1, slightly more flow if i remember correctly off the top of my head... I had one but decided to go bigger and ditch it.
it will max around 55 lbs/min.
Old Jun 17, 2007 | 08:42 AM
DrewS2k's Avatar
v8 destroyer
to each his own from what i hear it spools good and will max out right around high 400s maybe break 500 barely and if guy got 360 at 12psi on a conservative tune thats good for me
Old Jun 18, 2007 | 02:40 AM
rofuz's Avatar
Snail-Turbo *)
I got 443rwhp... could probably do around 500 with a better WG... full boost by 4
Old Jun 19, 2007 | 02:46 AM
DrewS2k's Avatar
v8 destroyer
thats awesome what boost did you hit that awesome nthats about what i want from this turbo
Old Jun 19, 2007 | 04:15 AM
rofuz's Avatar
Snail-Turbo *)
1.3bar = 18~19psi
Old Jun 19, 2007 | 06:08 AM
rofuz's Avatar
Snail-Turbo *)
on euro V-power from shell 99 octane pumpgas :P
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Ian_D
Oct 14, 2015 12:31 PM
erick31876
Sep 23, 2015 05:16 AM
gruss16
Sep 16, 2015 12:13 AM
sinistersam
Sep 13, 2015 07:17 PM
