Sponsored by: CARiD
Need help on removing exhaust port sleeves
Old Jun 11, 2007 | 08:29 PM
rotorizit's Avatar
Got Boost?
Question Need help on removing exhaust port sleeves
I blew up my 1990 13b turbo engine while running lean under full boost. The rear rotor housing got scraped up badly, so I need a replacement. I've got a perfect housing out of an '89 - '92 NA that I want to use as a replacement. My problem is the exhaust port sleeves are different between the turbo and NA housings. I was thinking I could swap the sleeves by drilling out the roll pins that hold them in on the sides. My question is, Can I swap the sleeves? And is drilling out the roll pins the proper way to remove them? Or is there another way to remove the sleeves?
Please help, I'd like to get my car back on the road ASAP, without buying a new housing if I can get away with it. Thanx, Machija
Old Jun 11, 2007 | 08:53 PM
jgrewe's Avatar
GET OFF MY LAWN
The best way I've found is to have a little ball of weld built up on the exposed end and then grab it with visegrips and twist it out. As for the housings being the same turbo to NA that should be you next question. I've never played with a turbo engine.
Old Jun 12, 2007 | 03:30 PM
Carzy Driver's Avatar
Law Breaker
I freeze the housing and use a slide hammer with a small machine screw. clean the roll pin and hole really well otherwise the carbon will keep it from coming out.
Old Jun 12, 2007 | 04:40 PM
dean7's Avatar
ROTor HEAD
I just got a newer engine from a really intelligent car guy/racer...anywho, he pulled out the exaust sleeves on the engine he sold me. Do you even need them? And if so, anyone have any for a 86-89 6 port (going in my first gen)
Old Jun 12, 2007 | 04:56 PM
rotorizit's Avatar
Got Boost?
Does anyone know if you can drive them through with a punch and not destroy the sleeves themselves?
Old Jun 12, 2007 | 05:00 PM
jgrewe's Avatar
GET OFF MY LAWN
You can't.
Old Jun 19, 2007 | 04:58 PM
rotorizit's Avatar
Got Boost?
That's what I thought. I'm going to try the machine screw and slide hammer then go fom there. Thanx guys!
Old Aug 6, 2007 | 07:02 PM
micah's Avatar
Winter sucks
So, I'm going to resurrect this thread. Its SOMEWHAT RECENT.
I've been trying this for a while now... and it seems that the roll pins always strip out whatever screw I try to thread in there... I want to exhaust this option first as it seems like the best way.. Next I'll try the weld method.. but I hate the idea of welding anywhere near my brand-new housings.
Any ideas as to why my screws keep stripping out? Am I rotarded?
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
Leeroy_25
Aug 17, 2015 12:53 PM
