reassembling port valve actuators -- question
Old Mar 29, 2002 | 10:11 AM
gvink's Avatar
I've been wallowing deep in my intake system, cleaning up stuck port valves, etc., and I can't remember the assembly order for the rods that extend through the extension manifold from the actuators to the actual valves themselves.
each rod goes into the extension manifold through a rubber seal. The rod has a groove in it to hold a V-shaped washer to prevent the seal from coming out. There's also a regular washer on the rod. My question: Is the regular washer supposed to go on the INSIDE of the V-shaped washer, against the seal, or on the OUTSIDE of the V-shaped washer next to the retaining plate (the one that bolts on with two phillips screws that always get rounded off)?
Thanks all.
Old Mar 29, 2002 | 02:29 PM
No7Yet's Avatar
Wow. That's deep. Unfortunately, it's been too long since I worked on an N/A that heavily. You may want to try the fc3s_org@yahoogroups.com email list. There are some top-notch N/A guys that will be able to answer your question in about 5 seconds Now, if you've got a question about a TII...
Good luck
Brandon
Old Mar 29, 2002 | 02:51 PM
SureShot's Avatar
Seduced by the DARK SIDE
Rubber inboard, metal outboard..
By the way, good luck with the lower intake gasket. I broke mine and it took 3 hours to clean up the stuck on pieces.
hotshot2014
Jul 18, 2017 02:30 PM
FC_DREAMS
Aug 30, 2015 09:12 PM
Marty RE
Aug 13, 2015 11:19 AM
