NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Help! Failed NY emissions test. Need good rotary shop.
Old Jun 2, 2007 | 02:09 PM
jaison's Avatar
Question Help! Failed NY emissions test. Need good rotary shop.
Hello everybody,
This is my first post and hopefully y'all can help me out here.
I just purchased my first Rx7 -1994 Touring. I just failed the emissions test for NYS inspection. =(
Here are the vehicle readings:
HC 2.28gpm (limit 0.80gpm)
CO 44.68gpm (limit 15.00gpm)
NOx 1.15 gpm (limit 2.00 gpm)
So it looks like I'm below the limit for NOx, but way above the limits for hydrocarbons and carbon monoxide.
The car isn't modified (yet) and the turbos feel good when I get into the boost.
The car has 60,900 miles on it and it was warmed up pretty good on my
way to the inspection station.
I've been told it could be:
EGR
Catalytic converters are worn out
Thermal reactor
Plugs
O2 sensor
Air pump
Any suggestions? Or can you suggest a good rotary shop in the New York City area?
Thanks.
-Jaison
Old Jun 2, 2007 | 08:28 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I'd start with the basics first and change the 02 sensor, plugs, and wires.
Old Jun 2, 2007 | 09:11 PM
NoDrySkin's Avatar
http://www.nyrotary.com/forum/
Old Jun 3, 2007 | 01:27 AM
gracer7-rx7's Avatar
needs more track time
I used to use J&R in Elmont 516.616.5812. The owner Joe always did right by me.
Old Jun 3, 2007 | 03:11 AM
jaison's Avatar
Sweet. Thanks for references. I'll check them out.
Old Jun 3, 2007 | 10:21 AM
ROTARYROCKET7's Avatar
Originally Posted by jaison
Hello everybody,
EGR
Thermal reactor
Plugs
O2 sensor
Air pump
Thanks.
-Jaison
holla at me, i got the connection =)
Im also in queens by LGA airport.
646-772-0222
Jason NYC
NYRA President
www.nyrotary.com
Old Jun 3, 2007 | 10:22 AM
Originally Posted by NoDrySkin
thanks for the bump =)
Old Jun 3, 2007 | 10:38 AM
NoDrySkin's Avatar
Yezzir.
Old Jun 5, 2007 | 03:08 PM
MADDSLOW's Avatar
17 second FD
What? In NY, cars before 1996 do not need to be emissions tested.
Old Jun 5, 2007 | 03:25 PM
ALNY93R1's Avatar
As far as I know you do, in Dutchess county it's just safety. When I lived in Yonkers I had to pass emissions with my FD, which passed all the time
Old Jun 5, 2007 | 03:45 PM
MADDSLOW's Avatar
17 second FD
That's interesting. Yeah they just do a quick visual of mine and slap on a sticker, no machine or anything. Takes about 5 minutes, tops.
Old Jun 5, 2007 | 09:39 PM
rotory4life's Avatar
I just got my Insecpetor lincesene and i learn anything in the Lower NY. NYC lets say they do emission regardless the year..... Upstate they just check to see if you have a cat that all
Old Jun 6, 2007 | 09:22 PM
jaison's Avatar
So can I just drive upstate or do I need to get the inspection done in NYC since I live in NYC?
Old Jun 6, 2007 | 09:38 PM
NoDrySkin's Avatar
I thought it was 1996 and up?
Old Jun 7, 2007 | 01:16 AM
MADDSLOW's Avatar
17 second FD
That's what I said... cars made before 1996 do not need to be emissions tested, at least not in my part of NY.
I believe if you brought your car into Dutchess county for an inspection, it would pass. Ask ALNY, he appears to know more about it than I do.
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
elfking
Aug 19, 2015 09:48 PM
