Canadian Forum Canadian users, post event and club info here.
Turbo flange for V-band
Old May 31, 2007 | 03:02 PM
IAN's Avatar
IAN
Rotary Reborn!
Were can I get one of these locally to fit my turbo. Cracked mine!
http://www.ssautochrome.com/level.itml/icOid/1490
Old May 31, 2007 | 03:43 PM
R.P.M.'s Avatar
Likes to swear....alot
The V-band cracked? I've never seen that before!
Try Vibrant, the best V-bands I've ever seen, they have a machined lip so they fit together perfectly and wont leak.
http://vibrantperformance.com/catalo...ef2e06c38ea0c7
Try pricing it through them first and pm me, I'll probably get it to you for cheaper.
Old May 31, 2007 | 04:10 PM
Nismo Convert86's Avatar
400WHP or bust
Ian, I'm sure I can get that welded for you when you come up in June if you can wait that long.
Here is a website to buy the flange.
http://atpturbo.com/
Old May 31, 2007 | 09:28 PM
IAN's Avatar
IAN
Rotary Reborn!
I was quoted $90 or something at the local speed shop for that 3" kit.
- Vibrant Performance V-band flange assemblies feature a unique "Male/Female" design to ensure proper alignment of the flanges inside the clamp.
This may cause a problem since the mating surface on my turbo is flat? What do you think?
Old May 31, 2007 | 09:30 PM
IAN's Avatar
IAN
Rotary Reborn!
I think if it was to be welded the v-band will not fit properly. I will just get it fixed completed eventually.
Not going to chance driving the car that far but thanks for the offer.
Wow mild steel are like half the price! But my exhaust system is SS.
Old May 31, 2007 | 10:13 PM
400WHP or bust
Ian take the turbo off, I emailed you at work so you can read more indetail tomorrow. Did the Vband on the Turbo crack? Because you can weld Mild to that no problem with a high Nickle filler rod.
Kevin
Old May 31, 2007 | 10:35 PM
R.P.M.'s Avatar
OK I'm a little confused....where exactly did it break?
I have a new Miller TIG welder if you need some welding done?
Old Jun 1, 2007 | 02:05 AM
400WHP or bust
Ian,
This guy has some for sale.
http://forum.teamfc3s.org/showthread.php?t=54575
Bored at work on nights, yields this.
Old Jun 1, 2007 | 06:15 AM
IAN's Avatar
IAN
Rotary Reborn!
http://forum.teamfc3s.org/attachment...9&d=1180659152
In that picture its not the v-band clamp. Its the exhaust pipe that has a cnc machined lip on it that you weld unto your dp and connect it to the turbo with the v-band clamp. It cracked right at that lip. Right around the lip on the exhaust pipe. It cracked before the weld that was used to weld onto my 3" exhaust.
I will see which direction I will head with this repair.
Gone for this weekend and the next two weeks so I gather it will not get fixed very soon
Old Jun 1, 2007 | 06:17 AM
IAN's Avatar
IAN
Rotary Reborn!
Ian,
Dam forgot my fc3s password. thanks for the link.
Old Jun 2, 2007 | 06:32 AM
IAN's Avatar
IAN
Rotary Reborn!
http://www.kineticmotorsport.com/pro...ge-440-29.html
This is the part I need
Old Jun 2, 2007 | 02:59 PM
400WHP or bust
Ian, before you go with SS again find out what Series it is, something like a 304 is going to be **** in that area again, It's like using the SSAC manifolds you want a SS series in the 316/321. Those have a much higher Chromium, and Nickel content; using a Series like this will prevent the flange from cracking again.
Personally I would just go with Mild.
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
