Pics of my IDA Weber setup
Old Mar 27, 2002 | 11:05 PM
REVHED's Avatar
Hunting Skylines
Here it is. I fabricated the carb linkage using parts from my old carby and some aluminium strip. You can also see the heatshield I made and the T2 alternator. The heatshield really makes a big difference as to how hot the intake gets.
Old Mar 27, 2002 | 11:28 PM
Felix Wankel's Avatar
Super Newbie
Looks much better
Old Mar 27, 2002 | 11:37 PM
REVHED's Avatar
Hunting Skylines
Thanks. For all the money I spent on that **** it would have to look better.
Old Mar 27, 2002 | 11:52 PM
Super Newbie
I wish I had a downdraft 2bbl carb for my RX-2. Damn top mount starter is in the way.
Old Mar 28, 2002 | 12:59 AM
V8kilr's Avatar
i thought the downdrafts suck because of the short intake manifold = no torque?
thats just what i read a couple of places,
that is a very nice setup though
im ver envious
Old Mar 28, 2002 | 01:27 AM
PaulFitzwarryne's Avatar
Apprentice Guru
Looks great. The interesting point is that in your Nikki set up you went to great trouble to have cold air ducting to the air filter. Why have you tried a different approach with the Webber? In my Lotus with twin 45s I used the same approach as your latest.
Old Mar 28, 2002 | 03:40 AM
REVHED's Avatar
Hunting Skylines
im ver envious
Yeah, down-draughts suck... but isn't that how all carbs work?
It's definately not the case that if you have short intake runners than you have no torque. Runner lengths do effect the power band but the effects are probably fairly minimal. Besides, if you want more power down low you can put smaller venturis in. I've got pretty big venturis in mine so it bogs down a bit if you floor it at low rpm but the top end is awesome.
Old Mar 28, 2002 | 03:50 AM
V8kilr's Avatar
oh thanks for the lesson,
i had a good option to pick up a system but didnt cause someone told me not to,
now if i can remeber who it is so i can kick their ***
Old Mar 28, 2002 | 03:52 AM
REVHED's Avatar
Hunting Skylines
I'm still debating whether to run a cold air intake as I'll lose that great induction noise.
I was thinking of making or buying (if someone already makes them?) an aluminium air box that fully encloses the intake trumpets and running some tubing to a big pod style K&N filter in front of the radiator. Should work well.
Old Mar 28, 2002 | 04:00 AM
REVHED's Avatar
Hunting Skylines
Was it in IDA? If so then whoever told you not to get it deserves a beating. I've heard IDA's are really expensive over there though.
Old Mar 28, 2002 | 10:09 AM
Nice job! Loved to hear the sound of it.
Old Mar 28, 2002 | 01:23 PM
mar3's Avatar
Administrator
What ees dees??? All that fancy carburetion and no direct-fire?? I thought you were serious about performance... calm down, jes havin' fun wit ya, dawg!!
Old Mar 28, 2002 | 03:11 PM
REVHED's Avatar
Hunting Skylines
What ees dees??? All that fancy carburetion and no direct-fire?? I thought you were serious about performance... calm down, jes havin' fun wit ya, dawg!! [/B]
I knew you'd say something about that. Direct fire does make a difference but more so if your tuning is off. I'd rather have the cleaner engine bay.
Old Mar 28, 2002 | 04:31 PM
gonzz's Avatar
Looks good.. nice job!!
Old Mar 29, 2002 | 08:00 AM
eddierotary's Avatar
back with rotaries
my question WERE IS THE FAN?????
Old Mar 29, 2002 | 08:42 AM
peejay's Avatar
Old [Sch|F]ool
I was wondering that the little bracket on the carby was for... then I remembered "oh yeah, right-hand drive"
Seriously beautiful! If you ever go to 13B power lemme know, want a 12A IDA manifold.
eddie: look carefully at the radiator... you can see the "****" of the fan-holding ziptie thingies sticking through from the frontside.
Old Mar 29, 2002 | 12:36 PM
Are you running premix?
Old Mar 29, 2002 | 05:12 PM
REVHED's Avatar
Hunting Skylines
Yep, I'm running pre-mix.
And peejay, you were almost right. The little things sticking through the radiator are actually bolts not zipties. If you look closely you can see there's a nice big washer and a nut attatched to them. Kind of hard to see because I sprayed em black.
Old Mar 29, 2002 | 05:31 PM
peejay's Avatar
Old [Sch|F]ool
Oh, hmm. My electric fan mounting kit came with specialized zipties that looked just like that on the non-fan side.
The sucky part is hitting big bumps, which makes the fan slide down, tearing fins out of the radiator in the process... next time I don't use those cheapo mounts!
Old Apr 1, 2002 | 02:41 PM
itzweapon's Avatar
I notice that your timming is advance quite a bit.. actually.. it looks like its as far as it will go..
Old Apr 1, 2002 | 09:30 PM
REVHED's Avatar
Hunting Skylines
Total advance is 25* L and 15* T.
We were playing around with the timing while the car was on the dyno and we found that we could run almost 30* with no sign of detonation but we backed it off to be safe.
Old Apr 1, 2002 | 09:45 PM
Directfreak's Avatar
I am a Jeeper Now.
Very Nice, Very Clean. Great Job.
Does it get cold in your part of the world?
In South Florida, I don't know how ANYBODY can live
without Air Conditioning - even in the 80 degree winters.
Old Apr 1, 2002 | 09:48 PM
riffraff's Avatar
smog nazi destroyer
in california , with the 100 + summers, i find a way to manage without one.
Old Apr 1, 2002 | 10:16 PM
REVHED's Avatar
Hunting Skylines
Does it get hot here? Try 100+ degree days in the summer and humid as hell. Probably quite similar to South Florida.
My excuse for not having AC is that it might be hot in summer but it's fast all year round.
Old Apr 1, 2002 | 10:23 PM
mperformance's Avatar
revhed what kind of porting in that beauty?
