Canadian Forum Canadian users, post event and club info here.
Results Shannonville Test Day May 21
Old May 22, 2007 | 03:48 PM
01Racing's Avatar
Go Hard....or Go Home
We went out with the Image Motorsports gang yesterday to Shannonville testing our new P.Port engine. WOW! I have never gone that fast in a straight line before. The engine is unbelievably responsive and pulls right to 11,000rpm! The car was on rails out there and ran very fast and very consistant. No power drop offs, temp spikes or anything. I did over shoot a few corners because I'm not used to the high end acceleration. An interesting side note, the rotors we used were a matched set from Mazda, but we DIDNT balance the rotating assembly. After talking with an engineer and seeing the rotor run in a housing (he had one set up) he said trying to balance it was a waste of money. After running yesterday to 11,000rpm all I can say is he was right. The old engine that was balanced is not a smooth a this one which isnt. The new engines eccentric shaft is micro polished and the rotors are race clearenced all done by Mazmark. The engine is proof that quality assembly and proper clearencing is what makes big power! Our next race will be Shannonville June 4
Old May 22, 2007 | 07:34 PM
IAN's Avatar
IAN
Rotary Reborn!
Nice. See you there.
Old May 22, 2007 | 07:55 PM
paul_3rdgen's Avatar
Too cold in the garage
How much power are you making? and how much does the car weigh??
Old May 22, 2007 | 09:52 PM
01Racing's Avatar
A good P.Port should put out between 300-320 hp at the engine, so about 260280 at the wheels. Engine os only about 2 hours old, so we havent dynoed it yet. The car weighs 2200lbs without me in it.
Old May 23, 2007 | 07:29 AM
pd_day's Avatar
Spoolin'
Sounds nice Al .....
You are putting down some crazy POWAH .... 300-320 hp at crank = 260280hp at the wheels!! How do you get traction???!?!?!?!?
Old May 23, 2007 | 10:49 AM
01Racing's Avatar
Sticky Hoosier tires for one, and because of my transmission I come out of corners at the bottom of the power band, so wheel spin isnt a problem, but it would be with the right gearing! 1st gear is just a big burn out though (lol)
Old May 28, 2007 | 02:01 PM
rx8volks's Avatar
rx8volks
nice and crazy power!.
rgordon1979
40
Mar 15, 2022 12:04 PM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
SCinfidel
Sep 8, 2015 05:36 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
