what to do with 2 stroke oil??
Old Mar 27, 2002 | 01:31 AM
ok all of my omp lines and all are gone on the engine im installing in my 86 rx7. what i need to know is. how do i go about putting in the 2 stroke oil?? do i still run normal oil in my engine and just when i put gas in it at the gas station i mix it with the 2 stroke oil?? its 100 to 1 right. so its how much 2 stroke oil per gallon of gas?? and can i run synthetic 2 stroke oil with that?? i just need to know this by tomm cause im putting the rest of my engine together and trying to start it tomm night. just wanna make sure i dont lock it up right when it starts. thanks
Old Mar 27, 2002 | 01:39 AM
Scott 89t2's Avatar
SOLD THE RX-7!
you put it in the gas, I'm not 100% sure on the ratio. might want to run more then that?? if 100-1. that means for every 100 gallons of gas, you add 1 gallon of 2 stroke oil. or 1/100 of a gallon or oil for every gallon of gas. that's as far as I can go since I'm a canadian boy and use liters
you still use normal oil in the motor. is everything blocked off? where the oil metting pump used to be and where the lines went into the housings?
Old Mar 27, 2002 | 02:00 AM
BadBoy's Avatar
use the 2 stroke oil for the chainsaw and bushcutter j/k
Old Mar 27, 2002 | 04:28 AM
You cannot use just any other 2 stroke. There's some made specifically for motorbikes and fuel injected engines. These do not clog up the injectors. I'm using Valvoline Multi Purpose 2 stroke. Before, they had a label which said "recommended for rotary engines".
The new bottles do not have them . I really don't know why but I still use them since it gives me good results.
I've heard Yamaha 2 stroke is good but pricey. Using pure 2 stroke for over 2 years, I've yet to have problems that's fuel related.
Old Mar 27, 2002 | 06:29 AM
Gefunk's Avatar
I use the Valvoline stuff with the little guy on front with the crotch rocket. My ratio is probably low, you use the little reading on the side of the bottle. I believe it goes by 8ths or something around those lines. I put in half of one of those every time I full up. Yes your car might smoke, however your seals will last longer.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
