New Gramlights problem with tire
Old May 22, 2007 | 09:06 AM
Monsterbox's Avatar
Mazzei Formula
put these new bad *** gramlights on perfect offset 17x9 +35 w/ 255's and 17x8 +30 w/ 235
front passenger tire was mounted backwards so i had it flipped...it has a small flat spot and is not perfectly round so the tire vibrates really bad even with a balance at two shops....is there such thing as a tire place that has a machine which will sand the tire round again...ive heard rumors of this type of equipment
and you guys thing i should drop it and roll the fenders or leave it?
Old May 22, 2007 | 09:43 AM
aznpoopy's Avatar
strike up the paean
its called shaving... and lot of autocrossers have this done to tires.
significantly reduces life of the tire, obviously. you should be able to find a place that can do this for you. but you should probably shave in pairs, at least...
depending on how much it costs it might be more worthwhile to just get a new tire if the other one is still brand new.
wheels look very nice. i would lower and roll, but if you are happy with it just leave it.
Old May 24, 2007 | 01:37 PM
cabaynes's Avatar
Old and grumpy
if the other tires are new, which they look to be, i'd just replace that tire all together rather than spending money to shorten the lifespan of the tire
Old May 28, 2007 | 08:16 PM
owen is fat's Avatar
tirerack in Indianna can do it
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
