Is Anyone Running 18x8.5+35 And 18x9.5+35
Old May 21, 2007 | 02:20 PM
upatnight's Avatar
i know 17x8+35 and 17x9+35 work. how about 18X8.5+35 and 18X9.5+35?
Old May 22, 2007 | 07:49 PM
hurleysurf24's Avatar
wtf rotary wtf
your going to need 5 mm spacers
Old May 22, 2007 | 07:56 PM
BASTARD's Avatar
you will need less offset for the front... the rears should be fine
take a look at the official wheel fitment thread in the tires and wheel section where this thread should be moved to
Old May 22, 2007 | 08:17 PM
rotaryracer11's Avatar
nah 17x8 with 35 should be fine
Old May 22, 2007 | 08:25 PM
BASTARD's Avatar
if you re read his post, he states that he knows that 8's will work in the front... but he wants to know if 8.5'will with a 35 offset.. and i know that my 17x8+35 where very very very close to the strutand therefore the 8.5 will more then likely rub
Old May 22, 2007 | 08:56 PM
upatnight's Avatar
bastard do you have a stock suspension? i have tein ra's they're a bit skinnier
Old May 22, 2007 | 09:06 PM
BASTARD's Avatar
I tried them with koni yellows/springs and G.E.T. coilovers... both were cardboard close.. but that was a 17x8... not a 17x8.5 which will be sheet of paper close if not touch
Old May 22, 2007 | 09:07 PM
BASTARD's Avatar
read this thread... you will learn a lot.. well worth the read
https://www.rx7club.com/suspension-wheels-tires-brakes-20/official-fc-wheel-fitment-thread-257700/
Old May 22, 2007 | 09:09 PM
rhscare's Avatar
Rotary No Ka Oi
I know its not constructive, but honestly...18's look terrible on the FC.
Old May 22, 2007 | 09:10 PM
chinkst3r's Avatar
i love my rice!!!
i got 18 x 7.5 x 35 in da front and 18 x 9.5 x 35 in the back, i have a 5 mm spacer in the front because it sits really close to the strut, but now it sits perfectly flush with the fender lol, in the back is alll clear
Old May 22, 2007 | 09:11 PM
chinkst3r's Avatar
i love my rice!!!
i'd be careful about the front because 18's are a bit bigger so it sits closer to the bottm of the spring holster... lol
Old May 22, 2007 | 09:23 PM
RETed's Avatar
Very common offset and width, but this is dependent on what size tire and what kinda struts you're using up front.
8.0", +30 would be a safe spec.
I put money the 8.0", +35 will hit the inside fender well on full lock on anything wider than a 215 tire...
-Ted
Old May 22, 2007 | 09:52 PM
Mills's Avatar
procrastination engineer
I used to agree with you!
But now I know better
Old May 22, 2007 | 09:59 PM
dwb87's Avatar
This is my social media.
Those rims look great Mills~
Old May 23, 2007 | 12:08 AM
Mills's Avatar
Thanks! I think they'll look even better with it lowered a bit.
18X8 +38mm F 225/40
18X9 +38mm R 275/35
I wish I could get wider fronts but anything bigger will rub with the stock suspension.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
