re-amemiya camber settings
Old May 19, 2007 | 07:30 PM
REHarrison's Avatar
S5 TII
just like the title says, does anyone know the camber settings for their FD or FC race cars??
Old May 31, 2007 | 12:53 AM
R1rotor's Avatar
No Rotor_No Motor
i would ask the alignment question... camber, caster, toe setting....in any case does any know those setting... i know that the caster and camber are a little higher, but what about the toe???
Old May 31, 2007 | 06:21 AM
wrankin's Avatar
Old Rotary Dog
Depends on the car, depends on the tires, depends on the track.
Search the section, it's been covered before. The best way to judge camber is to check temps across the face of the tire with a pyrometer right after you come off the track (in the hot pits, if possible).
In general for my FC it's around -2.5f/-1.5r for the camber, 0 toe f/r, and as much caster as I can resaonbly find (6+). It seems that most of the real racers are running more negative camber than that. Some people like playing around with slight amounts of front and rear toe, trading off straight line stability for turn-in. On a slower "tighter" track, this is likely faster, although I'm not good enough to where I feel it would make any signiicant difference.
-bill
Old Jun 1, 2007 | 05:52 PM
jkstill's Avatar
Searching for 10th's
-bill
Toe makes a very noticeable difference.
I am running toe out in front and toe in on rear in my autox miata, which is also the DD.
primerGrey
Aug 25, 2015 02:46 PM
sypath
Aug 23, 2015 10:15 PM
RaY358
Aug 19, 2015 11:44 PM
