Microtech CAS wiring help
Old May 18, 2007 | 07:59 PM
Cowzzz's Avatar
CAS wiring help
ok so i have been searching this forum for the last 30 minutes and cannot find any hard evidence of this but i was just curious if anyone had a diagram of how to properly wire up the cas to the microtech lt8??? everyone says that you are not supposed to match up the colors of the microtech harness to the ones on the existing cas plug but they don't say how it should be wired PLEASE HELP!!!!
Old May 18, 2007 | 09:37 PM
rx72c's Avatar
Top Answer: 1
do people actually look at the wiring diagrams these days?
its all their.
im looking at the wires on the CAS it self.
So green on microtech goes to green on CAS.
red on microtech goes to red on CAS
yellow on microtech goes to white on CAS
blue on microtech goes to white/black on CAS
Tell us how you go.
Old May 19, 2007 | 09:27 AM
Aaron Cake's Avatar
Engine, Not Motor
Well, I just opened the back of my LT8S manual and looked at the wiring diagram. According to the manual, it's
Microtech CAS
Red Red
Green Green
White Yellow
White/Black Blue
These wires are on the CAS side of the plug if I remember correctly.
Old May 21, 2007 | 07:17 PM
Cowzzz's Avatar
i know i looked at the wire diagram in the back of the microtech manual but i remember there being a debate on this forum about how to wire it up i cannot find this topic so i thought i just wanted to confirm.
Old May 23, 2007 | 09:21 PM
Cowzzz's Avatar
ok on the back of my microtech where the CAS wiring plugs in i have 3 wires. red, green, and a blue. according to the wiring digram red and green are inputs. now on my diagram it has no blue....does not tell me what it does. at my CAS connector i have a red,green,blue, and yellow. now i am assuming that blue would get 12V from the ECU to the CAS and yellow would be ground. well im not getting anything out of that blue wire. i back-probed the ecu and nothing at all. am i thinking about this all wrong or am i on the right track??
Old May 24, 2007 | 09:06 AM
Aaron Cake's Avatar
Engine, Not Motor
At the Microtech it's three wires. At the end of the harness it's 4.
The CAS requires no voltage to operate.
Are you following the wiring diagram in the manual?
Old May 24, 2007 | 12:18 PM
Cowzzz's Avatar
so the CAS needs no voltage to operate??
Old May 24, 2007 | 09:41 PM
rx72c's Avatar
Top Answer: 1
just wire it up like i told you. you will have no problems.
the yellow and blue are just earths. but hook them up like i have specified above.
Old May 25, 2007 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
As I said in the post above...
Old May 25, 2007 | 07:40 PM
Cowzzz's Avatar
well i got it to run. where i spliced into the cas it was after the connector. and for whatever reason the colors of the wires befour and after were different colors. so i went of the wires befour the connector and it fired over!!!! so thx for everyones help.
NEWGENRX7
Jun 26, 2019 12:20 AM
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
