dashboard removal
Old Mar 26, 2002 | 10:33 AM
cblake3's Avatar
dashboard removal
Anyone know if the steering wheel has to be removed in order to remove the dash on a TII?
Old Mar 26, 2002 | 10:42 AM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
I would remove it just to make it easier on myself. i have removed dashes with the steering wheel on and it is a major PITA
Justin
Old Mar 26, 2002 | 11:02 AM
The guage cluster I couldn't get out with the steering wheel still on. I would remove the wheel and save yourself the risk of breaking something while bending it to get it around the wheel..
Old Mar 26, 2002 | 11:24 AM
cblake3's Avatar
What is involved with removing the steering wheel. Do I need a wheel puller and all that stuff.
Old Mar 26, 2002 | 11:50 AM
Sniper_X's Avatar
you dont needd a puller.
Jut MAKE SURE that you mark the steering wheel and the steering shaft so you can lin them back up again!!!!!
Old Mar 26, 2002 | 11:57 AM
jimmyv13's Avatar
Round&Round not Up&Down
Yes, you'll need a wheel puller from any auto parts store. It's very easy and should take about five minutes.
Old Mar 26, 2002 | 11:58 AM
jimmyv13's Avatar
Re: you dont needd a puller.
How have you gotten your wheel off w/o a puller?
Old Mar 26, 2002 | 12:14 PM
Marc's Avatar
Newbie
You just keep the nut threaded on a few threads then pull like mad on the steering wheel. I made the mistake once of forgetting to leave the nut on I gave my self a fat lip in the process.
Old Mar 26, 2002 | 12:24 PM
FPrep2ndGenRX7's Avatar
Re: Re: you dont needd a puller.
Yes. I've pulled two without a puller. Take the nut off and start working it back and forth. Pull one side(3 o'clock position) then the other side(9 o'clock position). Mine came off after a minute or two.
Old Mar 26, 2002 | 12:27 PM
jimmyv13's Avatar
I've tried that before. Pulled and pulled until it felt like I tore both of my shoulders out of socket.... then I went to the store and got a puller
Old Mar 26, 2002 | 12:30 PM
oppressor666's Avatar
Like FPrep2ndGenRX7 said just work it around and eventually it will come off.
Old Mar 26, 2002 | 12:33 PM
SonicRaT's Avatar
Super Raterhater
I removed the steering wheel in my '57 chevy once without the nut on there, the car had no interior in it, so I ended up on my back with a headache after my head hit the floor. I was squatted down inside of it pulling and I toppled backwards and landed on my head.... not a fun moment.....
Old Mar 26, 2002 | 11:56 PM
fcturbo2's Avatar
I pulled my old dash off my T2 about 3 weeks ago. It was a bitch!..
Old Mar 27, 2002 | 12:17 AM
Silkworm's Avatar
Has been.. hangin' around
You should be able to undo the two bolts holding the steering column up to the dash, and work around it (including getting the cluster out.
That said, it's probably easier to pull the steering wheel. but it can be done with it on.
PaulC
Old Mar 27, 2002 | 12:22 AM
SonicRaT's Avatar
Super Raterhater
I had to remove the lower two bolts as well to even get my sterring wheel to come down, the two bolts that are on the firewall with that bracket that's welded to the steering column wouldnt allow it to move.
Old Mar 27, 2002 | 11:49 AM
Sniper_X's Avatar
thats what he was saying..
Only removign the bolts at the dash will allow the wheel to move up or down.
Old Mar 27, 2002 | 11:56 AM
SonicRaT's Avatar
Super Raterhater
I couldn't move mine at all after taking the two at the dash out, it was too stiff due to the lower bracket still being on, so I just took those off as well (total of 4 bolts) and it fell right down on the seat
Old Mar 27, 2002 | 11:57 AM
Skippydog's Avatar
Dont listen to rat he hits things with a hammer when he cant get it. Ask him about his blinker
Old Mar 27, 2002 | 11:59 AM
SonicRaT's Avatar
Super Raterhater
That was totally unrelated! I wanted to get my steering wheel off so I could get to my gauge cluster easier, and lets just say I missed the steering wheel
Old Mar 27, 2002 | 12:01 PM
Skippydog's Avatar
Yea you smashed it with a hammer
Old Mar 27, 2002 | 12:03 PM
tmak26b's Avatar
You can take the instrument cluster out with the steering wheel on on cars with tilt steering. The ones without will be a bitch
Old Mar 27, 2002 | 12:04 PM
SonicRaT's Avatar
Super Raterhater
i kept having problems with the plastic surround, it was a pain in the *** to get it out, so I was going to remove the wheel because I had wanted to do quite a few things at the same time, but I gave up on that idea.
Old Mar 27, 2002 | 12:07 PM
Skippydog's Avatar
And then you got pissed and beat the sh** out of your blinkers
Steelwheelz
Sep 15, 2015 03:22 PM
