O2 Sensor and Mystery Transmission Wire
Old May 13, 2007 | 04:39 PM
iSP33D-for-J3SUS's Avatar
s4 Tails for Life!
Talking O2 Sensor and Mystery Transmission Wire
Yes, this is another, "where does this wire go?" thread.
Firstly, where does the O2 sensor wire go? I have it plugged into the red wire with the flat "quick-disconnect" style end, where does it go from there?
I also have a single wire coming from the top of the transmission bellhousing (88 NA). What does this plug into? I had them plugged into each other but the car was idling very poorly. I assume this isn't right. If it is I need to check for vacuum leaks.
Where do these wires go?
Cheers,
Cody
Old May 13, 2007 | 07:44 PM
s4 Tails for Life!
Talking
I'm guessing the transmission wire is a ground wire. I have grounded it to the firewall. Now I just need someone to tell me / show me a picture of where the o2 sensor wire goes. Thanks in advance.
Cheers,
Cody
Old May 13, 2007 | 08:18 PM
s4 Tails for Life!
Someone, PLEASE. Yes, I'm bumping, no, I don't care.
I have no idea where this wire goes. I have searched, looked in the FSM and my Haynes manual, I can't find the connector for the other end of the o2 sensor. If you know where it is, PLEASE tell me.
*yeah I'm cranky.*
Cheers,
Cody
Old May 13, 2007 | 10:48 PM
s4 Tails for Life!
Talking
Still can't find an answer anywhere.
Cheers,
Cody
Old May 14, 2007 | 06:56 AM
My5ABaby's Avatar
Rotaries confuse me
FFS you're impatient. I'm surprised I'm even trying to help you.
On my 86, the O2 sensor plug comes out of the harness under the UIM. It's a single spade green connector.
Btw, Sloth is one of the seven deadly sins.
Old May 14, 2007 | 07:25 AM
spot_skater's Avatar
The Cause of Death
Look on the back of the UIM, passenger side. You should see a green connector somewhere back there. It's kinda hard to see.
James
Old May 14, 2007 | 10:46 AM
s4 Tails for Life!
Talking
I appreciate the help.
I've had my car torn apart for weeks doing this clutch change, so yeah, I'm impatient because I'm ready to drive her again!!
Cheers,
Cody
Skeese
65
Mar 28, 2017 03:30 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
