Turbo rear end or not???
Old May 10, 2007 | 08:47 PM
alemmons's Avatar
89 GXL Turbo
Veteran: Marine Corp
I have a rear end from a wrecking yard that is marked as a 87 turbo rear end, but the driveshaft that I thought was turbo doesn't line up. I don't know for certain that the driveshaft is a turbo driveshaft, so is there any way I can identify if it is a turbo rear end or not? The half shafts or any physical markings or shapes? Thanks.
Old May 10, 2007 | 09:02 PM
Asterisk's Avatar
iRussian
The turbo trans/ differential pumpkin are beefier & are ribbed for her pleasure.
The TII bolt patterns are also larger. IS the car 5-lug? If it is, it's more likely to have a TII one,
through a conversion CAN be done.
Old May 10, 2007 | 09:18 PM
alemmons's Avatar
89 GXL Turbo
It is 5 lug. I at least knew that much. I will go take a couple pictures and maybe that will help.
Old May 10, 2007 | 09:22 PM
cpubugs's Avatar
Lovin my 7
Here is a tII diff
Old May 10, 2007 | 09:39 PM
alemmons's Avatar
89 GXL Turbo
Here are some pictures. Ignore the wheel, I know that isn't a turbo wheel, it is just what I have on one end.
Old May 10, 2007 | 10:46 PM
alemmons's Avatar
89 GXL Turbo
Unforunately, I just looked under the gxl and it's rearend is ribbed also, so there must be more to this.
Old May 10, 2007 | 11:13 PM
Asterisk's Avatar
iRussian
The turbo one is like, dimensionaly biggerm, and at least the trans DOES in fact have more ribs.
Also, look at the pic posted, the front of it is different.
Old May 10, 2007 | 11:21 PM
sLoW'n'StEaDy's Avatar
i guess first thing would be to make sure it is a LSD. I have a TII rearend sitting out in the garage, i can get measurements and pictures if you'd like something for comparison
Old May 11, 2007 | 12:17 AM
alemmons's Avatar
89 GXL Turbo
Anything would help. I believe the half shafts are supposed to be different, but I don't know if it is the length, splines, or diameter.
Old May 11, 2007 | 12:21 AM
slpin's Avatar
7th Heaven
measure across, from 1 bolt to the other on the halfshaft
then we can tell you.
Old May 11, 2007 | 08:35 AM
alemmons's Avatar
89 GXL Turbo
Center to center on the bolt holes is 2.75 measured with a tape measure. Does anyone know what the differences are there for turbo and na?
Old May 11, 2007 | 12:05 PM
pistones's Avatar
if you compare the two pics of the cover, look at the ribbings. the turbo has more ribbing from the drain plug to the axle, the NA has one less ribbing and are more further spaced apart.
Old May 11, 2007 | 12:12 PM
N/M couldnt figure anythign out
Old May 11, 2007 | 02:14 PM
alemmons's Avatar
89 GXL Turbo
Thanks for the help everyone. It must not be turbo, because I got it up on jack stands and spun one wheel. The other wheel moved in the opposite direction. My understanding is that alone lets me know it isn't a LSD and therefore not a turbo rearend. Oh well. The search continues.
Old May 11, 2007 | 07:25 PM
Icemark's Avatar
The rear end in your pictures is a non turbo S4 LSD rear end, probably from an 88.
If the other wheel moved the opposite direction, the clutch pack is probably worn out.
Old May 19, 2007 | 03:14 AM
SpikeDerailed's Avatar
This sh*t burns oil!
Since this topic is about FC differentials I figure ill ask here instead of making a new topic.
Does the S5 convertibles come with a open or limited slip rear end? Its an A-Spec car with n/a engine. Im going to look at it for a second 7 this coming week and wasn't sure.
FD7KiD
15
Feb 26, 2021 10:12 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
