Another Timing Question
Old May 9, 2007 | 01:35 PM
Newbs's Avatar
My timing light does not seem to work on the RX7. Is there a way to set the timing without using a timing light on an S5 NA? Could someone please give me a "How to" or a link?
Yes I searched and read the FSM.
Thanks
Old May 9, 2007 | 01:44 PM
TehMonkay's Avatar
Back in the game
You have to have a timing light pretty much , you can try and get it close by taking off the cover on the cas and aligning it properly.
Old May 9, 2007 | 08:30 PM
HAILERS's Avatar
HAILERS
Since you read the FSM then you know how to aling the front pulley with the fixed pointer.
Do that then take the black cover off the cas.
Turn the body of the cas til the two pointers on top of the cas gear point to where they just cut the edge of the black coil like assys where I pointed to with a blue line in the attached jpg.
Then bolt the cas down and start the engine. The timing will be almost right on withing five degrees anyway.
What's with the timing light? Flickers????? Only seems to flash every so often? Then reverse the clamp of the timing light (the clamp on the lead wire ) to face the opposite direction. The light should flash more consistently then.
Don't bother looking at the trail It's a waste of time. Just the Lead wire(s). One of the lead wires is all you need to use. Both fire at the same time.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
