installing the stock wiring harness
Old May 4, 2007 | 04:00 AM
slo's Avatar
slo
registered user
Anyone have any pointers on installing the stock harness. I'm to the point where the rats nest is going down and I just can't get shyt to fit together.
I searched, but couldn't find what I was looking for?
Old May 4, 2007 | 04:32 AM
Fsunoles06's Avatar
Assuming you're replacing you harness with a new one, take lots of pictures with a digital camera if possible. label the connectors with numbers and masking tape. As far as the rats nats goes. I would just go non-sequential and be done with it.
Old May 4, 2007 | 10:29 AM
cewrx7r1's Avatar
Eye In The Sky
This is where the mechanics get seperated from the want-a-bees.
Intuition and skill are required here.
Old May 4, 2007 | 10:36 AM
Mahjik's Avatar
Mr. Links
What exactly is not fitting together?
The FSM has the wiring harness routing in a diagram. I've posted a JPEG of the image here before but the search function is waiting on the forum upgrades to find it.
Old May 4, 2007 | 11:41 AM
dgeesaman's Avatar
I had some fun fitting the harness in the area where it passes around the LIM and across the injectors.
These should help:
https://www.rx7club.com/showthread.p...arness+routing
https://www.rx7club.com/showthread.php?p=6700794
Take your time, don't break anything.
Old May 4, 2007 | 01:50 PM
slo's Avatar
slo
registered user
Thanks, I havn't broken anything, yes its a new harness, to late to mark everything but thats not an issue, I know where all the plugs, um plug into.
Its made harder by the fact that I wrapped the entire harness with heat tape, making it a good 2mm thiker, everywhere.
I am a decent mecanic/fabricator this is just something I shouldn't have tackled at midnight after 8 corona's.
But no harm done and thaks for the links.
Old May 4, 2007 | 04:07 PM
gracer7-rx7's Avatar
needs more track time
Its too early for Cinco de Maio, mang. Lay off the Coronas for a couple more days
Give a shout if you need a hand. I'm local.
immanuel__7
89
Sep 5, 2015 10:23 AM
BLK 93
Aug 19, 2015 03:47 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
