pros and cons
Old Apr 30, 2007 | 01:17 PM
viviorunitia88's Avatar
Boost like crazy
pros and cons
what are the pros and cons to a nonsequential turbo set up since i will be going to single turbo in a few months once i have that much cash
Old Apr 30, 2007 | 01:21 PM
Authentikdit's Avatar
1 pro is a much more simplified engine bay..1 con is that you don't spool as quickly as you do when running sequential
Old Apr 30, 2007 | 02:05 PM
jojodotcom's Avatar
if you are going single, why do you want to go non-seq for just a few months?
anyways~
pro: simplified engine bay, less hoses to worry about, simple boost pattern, easier to stay off boost when you need to (street use, driving with cold engine)
con: lose some low end torque...
Old Apr 30, 2007 | 04:14 PM
dabigesii's Avatar
Back to basics
Pro: easy to diagnose problems, linear power band, don't have to worry about solonoids and vacuum lines popping off and breaking.
Con: no instant boost, lag...although I see 7psi at 3000rpm and full boost by 3500rpm
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
