which plugs?
Old Apr 29, 2007 | 03:47 PM
gonzz's Avatar
which plugs?
Going to dyno my car next weekend. What plugs should i run?
13B-REW
SP
GT35R 1.0 T4
15 PSI
850/1680
Jacob FC1000 ignition amp..
Thanks
Old Apr 29, 2007 | 05:27 PM
bobybeach's Avatar
i think stock plugs will be fine for that psi.
Old Apr 29, 2007 | 08:59 PM
atihun's Avatar
We have crappy gas here in SoCal, 91 octane.
I have a similar setup as yours and am using B10EGV and B9EGV's. They need a small socket.
When I went to tune for 16psi, I was informed to run the 10's in the leading and 9's in the trailing. Runs great.
Old Apr 29, 2007 | 09:26 PM
BLitzed33's Avatar
9's all way around, any higher then 20 lbs, go with 9's in leading and 10.5 in trailing, the trailing plugs can actually act like a glow plug sometimes and cause issues, thats you run a colder trailing plug...if you were to run 25+ run 10.5's at least all way around.
Old Apr 29, 2007 | 09:31 PM
No_Rotor_RX7's Avatar
i always run the cheap as hell BR10ES (20+ psi tho). i don't even use the trailing ignition... but you should atleast run 9's like blitzed said
wretchedegg
Nov 19, 2025 03:07 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
