Help Wont Start
Old Apr 24, 2007 | 12:05 AM
smitty95's Avatar
Help Wont Start
hello
95 rx7 silverstone 34,000 bought new in VA vin #313
just fixed a vacuum line and had to remove and reinstall alternater , i have done several times, forgot to disconnect battery and did get a spark from wrench near alternator "me bad" . Put all back together there is one blue eletrical connector not plugged in i cant remeber ever unplugging it is it supposed to be disconnected ?
Car will not start just cranks over, no dash lights. no radio, no horn, no dash readout at all ,headlights, work interior fan motor works?
Did i fry 18-811 main relay? or other relays or fuses ? Please help
many thanks
smitty
Old Apr 24, 2007 | 12:09 AM
sevensix's Avatar
rotor rotor pow.
did you check to see if the battery is fully charged, or for the hell of it, get it charged. the blue plug is probably the one for california cars only(smog)
Old Apr 24, 2007 | 12:13 AM
smitty95's Avatar
battery fully charged red optima, i keep it on a battery tender ? and thanks about the blue plug , i wont keep searching !
Old Apr 24, 2007 | 10:50 PM
smitty95's Avatar
problem fixed wont start
first make sure battery is disconnected, this is what sent me on this problem!
found the problem, main fuse 120amp along side battery, you need to take a flashlight and magnifier and examine the fuse to see the break, i missed it the first time ! and there are nuts on each side of the terminal loosen or the fuse wont come out.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
