Megasquirt Megasquirt 12A Mild/Extend Port Dyno result
Old Apr 22, 2007 | 05:22 AM
Jobro's Avatar
SAE Junkie
Finally got the car on a dyno, I'm pretty happy with that result.
114.7rwhp = 86rwkw
Out of interest, that rise in the power around 134kph was well off the 8000rpm racho.
That run was done with the megasquirt controlling my ignition, but stock nikki carby rejeted for my motor.
I will put up a map of my timing map later
Was running 28BTDC timing with 0 split after 5000rpm.
Old Apr 24, 2007 | 12:38 AM
Jobro's Avatar
SAE Junkie
no comments???
Old Apr 24, 2007 | 11:12 AM
T2GTUS's Avatar
nice jobro! that afr is pretty darn flat ... interesting though as your afr did go down a bit after 8000 you made some more power ... might be worth looking into. Is this carb run a baseline test for injection later?
Old Apr 24, 2007 | 05:23 PM
Jobro's Avatar
SAE Junkie
Most definetly yes!
I had a mate mention the same thing about the AFR and the power going up, hrm.
Odd to see a Small Streetport making power way above 8000rpm with a standard carby too :S
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
mulcryant
Sep 9, 2015 05:24 PM
doritoloco
Sep 5, 2015 12:41 PM
