Sponsored by: CARiD
What Obd Is The Rx-7 1993???
Old Apr 20, 2007 | 09:20 PM
GabrielJouChan's Avatar
Newbie
Hello, how are you, can someone can tell me if the RX7 FD3S of 1993 is an OBD system??? and what OBD is? OBD1 or OBD2, and the connection of the OBD where is located in the car thank you
Old Apr 20, 2007 | 09:28 PM
RETed's Avatar
No, US-spec RX-7 ever came with OBD...
-Ted
Old Apr 20, 2007 | 09:29 PM
nas nas's Avatar
smokinfd3s!!!
should be obd 1
Old Apr 21, 2007 | 01:44 AM
RETed's Avatar
Fricken idiots...
*sigh*
-Ted
Old Apr 21, 2007 | 02:29 AM
rotor rod's Avatar
Lounge amateur **D
-Ted
That's weird, in the the late 80's CARB required all new vehicles sold in California to have some basic OBD capability.
What gives? Were Rotaries exempt?
Old Apr 21, 2007 | 02:57 AM
rynberg's Avatar
1988-1995 cars sold in California required OBD (OBD-1), so all US cars in those years have OBD capability. 1996+ cars require OBD-II, which was too expensive for Mazda to justify further importation of the FD to the USA.
Old Apr 21, 2007 | 03:22 AM
AHarada's Avatar
Fricken idiots...
*sigh*
-Ted
Old Apr 21, 2007 | 03:26 AM
rotor rod's Avatar
Lounge amateur **D
Thanks for the info rynberg!
Old Apr 21, 2007 | 03:45 AM
rotor rod's Avatar
Lounge amateur **D
There is a small black box next to the battery that says "diagnostics", you need to get yourself a jumper wire, then with the key off use the jumper wire to jump "TEN" to "GND", you can find the pin location under the box lid.
Turn the key to the on position and watch the "MIL" light flash, count the number of times the light flashes. Codes are in single or double digits, in example if the light flashes 5 times then a long pause , then flashes five times again your trouble code is 5, if you get two flashes short pause then six flashes your code is 26.
The code will keep repeating, just remember that the code starts after the long pause.
Sandro
3rd Gen General Discussion
24
Dec 30, 2017 03:35 PM
1987 T2
11
Apr 1, 2017 11:59 PM
