Sponsored by: CARiD
New radiator spewing out fluids?
Old Apr 20, 2007 | 04:41 PM
Barcode_Racing's Avatar
Alright, I bought a new radiator the other day for my 86 Rx7. Its a little different tho. It has a rad. cap on the radiator wich my original didn't... But I plugged the over flow gate on the original Over flow cap and routed it to the new radiator.
But after I drive the car for a 5 or so minutes it'll overheat still like it has no coolant but its full. And once I turn it off and let it cool down and try to crank her over it'll spew coolant everwhere! Do I need a new water pump? I already replaced the thermo and hoses... what else could it be. There is a crack in the block by the spark plugs about 2" away and it leaks a little coolant but not much... I was gonna get it sealed
What should I do?
Old Apr 20, 2007 | 04:59 PM
Tom93R1's Avatar
gross polluter
Where does it spew coolant from?
You dont need a new water pump unless the weep hole is weeping or it doesnt turn freely.
Old Apr 20, 2007 | 05:14 PM
its spewing out of the overflow tank... heavily
Old Apr 20, 2007 | 06:44 PM
socalrotor's Avatar
search..... BLOWN WATER SEALS. You need a rebuild. Sorry to break it to ya.
Old Apr 20, 2007 | 09:34 PM
thats cool i thought that was it thanks.
Bojmend
Oct 7, 2015 09:32 PM
JoesFC
Oct 5, 2015 08:10 AM
Hipsiguy
Sep 14, 2015 05:25 PM
Frisky Arab
Sep 4, 2015 06:17 PM
