HKS wastegate spring question
Old Apr 20, 2007 | 03:25 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
I have a 50 mm HKS wastegate with the 14 lb spring installed. i Have a new engine with single turbo kit composed of different brands. I ordered a 7lb wastegate spring to break the engine in on and work out any bugs i might have. The spring is obviously lighter, but the diameter is smaller and doesnt appear to fit in the wastegate as neatly as the stock spring. It has probably a good 1/4 inch all the way around difference. (serving from memory as i put the other spring back in) I would think the springs are supposed to be the same diameter. Can anyone confirm this? Would running a smaller width spring cause any issues?
Skeese
65
Mar 28, 2017 03:30 PM
Turblown
Aug 14, 2015 04:48 PM
