injector duty cycle for a stock fd ecu
hi, i saw this post in the second gen section, https://www.rx7club.com/forum/showth...tor+duty+cycle and was wondering if anyone in the third gen section knew anything about it. it mainly talks about the injector duty cycle for a stock ecu for a fc and was wondering if there was any kinda injector duty cycle limitation that stock fd ecu's have? also, is there any other way to find out what the injector duty cycle is other then buying a apexi avc-r or a hks injectordutycycle sensor.
thanks
thanks
Trending Topics
hey guys, i found this on the site j9fd3s posted, had to dig around a little to find it, not sure if its right since i dont have a clue yet on how to read it, http://www.wvinter.net/~flanham/wlan...el/basemap.jpg
Originally posted by j9fd3s
if you keep looking on that site he tells you how to convert the pfc #'s into miliseconds
mike
mike
It is a basic Load vs. RPM map, meaning it is a 20x20 matrix in this case. Each column is a 400 RPM band up to 8000 RPM, and each row is about 1/10 bar, the highest row is total vacuum, 0psi/vac occurs between rows 10 and 11, and full boost is on the bottom row 20.
So as the engine revs up, the value the engine uses (the "cell") travels in that matrix to the right, and as the engine makes more boost the cell travels downward.
Wade
Wade
sherff
Feb 24, 2019 12:09 PM
Megasquirt timing map and EGt ?? what do you guys think
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
