Sponsored by: CARiD
Need help with fuel recommendation for Race 13B
Old Apr 19, 2007 | 08:01 AM
Redshft's Avatar
Spinning Dorito
Not sure where else to put this, so "General" seems like a good spot.
Basically, trying to figure out what I should be running for fuel in my FC race car.
I purchased this car over the winter after it had been sitting in storage for several years.
S4 non-turbo 13B with almost no miles since "race" rebuild
converted from FI to Weber 45DCOE Carb w/ Racing Beat manifold, Racing Beat Header, HKS exhaust.
Heavily ported. On engine dyno (according to reports as I bought the car after the build) car made 270hp at 7600rpm. Idles ok, but it's pretty "lumpy" so my best guess is they did a Bridge Port.
Apparently they used new Turbo II irons when the built the engine, but the car is not Turbo'd.
OMP is disabled (since a leaky OMP is actually what caused the car to blow up the first time.)
Now, most stuff I'm reading says this should run fine on pump gas with pre-mix.
However, notes from the engine builder (very respected racer and mechanic locally for the last 20+ years. I know he's good, but he's not a "rotary" guy. He primarily races Nissans) indicate that the car should be run on VP C-12 race gas or similar.
He indicated that this was more for the lead to lubricate the seals than it was for the Octane. i.e. his notes say it will run on pump gas "ok" with enough pre-mix.
This seems a little bit excessive to me, which is why I'm here.
Any thoughts on the fuel requirements for this thing?
I'm torn between thinking "well, this old-time racer and engine builder must know" and thinking "well, he IS an old-time engine builder and racer and probably thinks EVERYTING should be running C-12 race gas, including his lawn mower."
If he was a rotary specialist I wouldn't even question, but he's not, so here I am.
My concerns are primarily, in order:
A) I want to run whatever is best for my engines life
B) I don't want to burn money I don't have to.
C) I don't want to hurt the performance running 15 pts. higher octane than I need and the engine can barely burn the stuff.
Also, any mid-ground that people have used?
i.e. pump gas with something like Red Line Lead Substitute added?
Any ideas would be great. I've been doing a ton of reading, and everything I read just confuses me more.
A bit of the backstory, for those who care:
It's basically an overbuilt IT/underbuilt GT class car, but should be very competitive in the local regional club-racing I'll be doing with it.
Seeing as how it is local club-racing, I don't want to burn money I don't have to.
The engine was blown up, rebuilt, dynoed, put in the car, car ran 1 lap, blew the clutch, had the clutch replaced, went into storage for a few years and hasn't raced since.
The challenge is, most of the information I have is from the previous owner of the car, who isn't mechanically inclined, but used to own a Mazda dealership, and I know he spared no expense on the car. So, I've got his memories, plus a few notes from the builder and local people who "know the car."
Thanks in advance for any input. I really am having a hard time deciding what to do. The group order for C-12 is going in amongst some people from my race series tomorrow, so I'm trying to figure out if I should get in or not.
Old Apr 20, 2007 | 05:31 AM
Redshft's Avatar
Spinning Dorito
So, nobody has any thoughts? (Other than the fact my original post was a little too long and rambling?)
Old Apr 20, 2007 | 08:15 AM
Mahjik's Avatar
Mr. Links
IMO, the octane as more to do with the tuning rather than lubricating the seals.
Old Apr 21, 2007 | 06:58 AM
Redshft's Avatar
Spinning Dorito
That's what I was thinking as well.
He was looking at the lead for the seals. It's tuned for more better then pump regular, but doesn't need 108 either.
I actually emailed VP Racing (and got a personal answer back in about a half hour, very impressive) talking aout the car and build etc.
They recommended Motorsport 105L or Motorsport 98L. (The 98L is the spec fuel for the STAR Mazda series) so that looks like the way to go.
Old Apr 21, 2007 | 07:14 AM
diabolical1's Avatar
i guess it all comes down to where and against whom you plan to compete. personally, with the Weber, i'd use pump gas and premix. if you know how to tune a carb and set timing, you should be fine.
Old Apr 21, 2007 | 07:42 PM
Rx-7Doctor's Avatar
Pump gas is all you need. Only turbo or supercharged rotaries require higher octane. Trying to use a higher octane fuel in your case will probably yield poor results.
Old Apr 30, 2007 | 03:01 PM
Don49's Avatar
Smile
High test pump gas ( I use Sunoco 93 octane ) With 1 ounce per gallon of two cycle oil ( Redline or it's equivalent ). This is in a street port SCCA legal EP motor with over 230 hp on the dyno. This is the reccomendation from my engine builder, Jesse @ Prather Racing, who is a rotary perfomance specialist.
Good luck!
Don49
Old Apr 30, 2007 | 04:47 PM
Rx-7Doctor's Avatar
Well, I don't agree with that.
It's been proven that the low octane fuel for non boosted engines is better and makes more Hp than the low volitile high octane fuel.
Old Apr 30, 2007 | 06:33 PM
jgrewe's Avatar
GET OFF MY LAWN
Jesse knows his **** but I've seen the results rx7doctor has seen with lower octane numbers. We got the best power with 89 octane and even went looking for 87! It could be the different blends used in different parts of the country at different times of the year. Maybe the 93 is more consistant nationwide?? Who knows.
Old Apr 30, 2007 | 07:17 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
i've always used 89 octane + premix on my 12a bridgeport. You don't need the fancy VP Racing Fuels for a n/a rotary. Save the $$.
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
