Air Pump??
Old Mar 23, 2002 | 02:02 PM
87GXLRX7's Avatar
Air Pump??
Should i Remove my air pump, i have no cats and therefore believe i don't need a air pump corect me if i'm wrong. Now the how to remove the pump is my question? and what about the EGR valve can i simply put a BB in the line to block it off..?? thank's for your help
Old Mar 23, 2002 | 02:35 PM
FC Drifter's Avatar
Damaged Little F*cker
yeah ditch the airpump for sure man, especialy if you already dumped the cats. and about the EGR, yes you can dump it too. somebody makes block off plates for it, as well as the ACV. mine are homemade so i dont know who sells them. i would remove the EGR, not just block it off. the 13b can be run without any of its emmisions equipment on it. mine does anyway
Old Mar 23, 2002 | 02:53 PM
RotorMotorRX7's Avatar
Racingbeat and mazdatrix offer the plates if you want to buy them instead of making them.. they are like 6 or 7 bucks .. mad cheap!
Old Mar 23, 2002 | 04:01 PM
flubyux2's Avatar
Thats not an FC...
sure they are cheap, the hard part is puttin them ON...buried under the upper intake, TB, vacc. spider, wiring...etc...
what happens if you just unplugged the EGR solenoid? does the engine create enough exhaust pressure to force the EGR open at high rpms, or would it remain shut forever?
chris
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
