Microtech wide band
Old Apr 17, 2007 | 09:22 PM
ColdSeven's Avatar
in between builds
wide band
so i tried to search for this and no results...is it possible to wire a wide band into the stock O2 sensor wire so that the AFR's will be accurate? i may not have explained this very well but i can't get an accurate readout for the AFR's it doesn't match what the wideband says.
please let me know if anyone has tried this
-ColdSeven
Old Apr 17, 2007 | 09:34 PM
oo7arkman's Avatar
In the Garage
Need to know what WB you have, Just alil more info.
Short answer is this is possible on some wb's.. ex.My innovate will allow for this.
Old Apr 18, 2007 | 08:48 AM
Aaron Cake's Avatar
Engine, Not Motor
Not possible without a box to convert it to a narrrow band signal. I think the LC-1 does this.
Old Apr 19, 2007 | 10:19 PM
ColdSeven's Avatar
in between builds
ok well here's what i have...microtech LT10s
i don't have a WB yet that's why i want to know what the deal is with this so i can get the one i would need....
on top of this i got a new problem, for some reason my temp guage is reading "-0C" and the top rad hose was sucked flat no cooliant cycling through it at all.
i know this^^^is the wrong section but im stumped and need some wisdom, please help if possible
-ColdSeven
Old Apr 20, 2007 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
Massive airlock in the system?
Old Apr 20, 2007 | 08:44 PM
ColdSeven's Avatar
in between builds
^^^well update...both the caps were **** so i replaced them. haven't figured out why i can't get a reading on the Microtech JDM motor not sure if that has anyting to do with it.
any ideas? and no not airlock either
Old Apr 22, 2007 | 07:02 PM
ColdSeven's Avatar
in between builds
well figured out a few things about the current problem it was a loose connector to the neck on the water pump, feel a lil stupid about that one and one of the wires in the harness for the MT was not soldered together so it worked loose, i then went through and fixed it all there may still be some wires that need to be soldered so i will go through this week and check them all. not happy about this one but oh well.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
manoflego
19
Sep 30, 2015 05:19 AM
