need help on engine choice
Old Mar 23, 2002 | 01:44 AM
cleung15's Avatar
Question need help on engine choice
I need help on engine choice. There are so many choices from rebuilding my own motoring to getting different j-spec motors. My ride is 88 TII w/ 95,000 miles on the clock. I try to set up a long term project which hopefully get to 400 rwhp level. Now the question is, what platform should I start? I know all other component such as fuel and ignition should go with the project, too but I try to set the first step which is the engine. Please help.
Old Mar 23, 2002 | 03:34 AM
FC Drifter's Avatar
Damaged Little F*cker
unless you want a ported motor, then just buy a used 88 T2 motor. j-specs are the easiest to come buy and prolly wont cost you more than a grand. if you want 400 hp then you will need a turbo that is not stock and the 88 motor can take it, so just stick with that
Old Mar 23, 2002 | 10:11 AM
InfiniIIIREX's Avatar
A street port and a large turbo should do the trick.
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
86rxNa
Aug 11, 2015 11:51 AM
