GT 42 manifold
Old Apr 16, 2007 | 04:25 PM
bori113's Avatar
GT 42 manifold
Would this J bend work to make a manifold for my Gt42 i know is heavy you guys think this would hold if not where can i get the pipping from. Thanks
here is the Jbend from summit
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 16, 2007 | 04:50 PM
Turblown's Avatar
Turn up the boost
If you're going to use that thin of a wall I would atleast use 321SS;
http://www.burnsstainless.com/321tub...ubends321.html
Old Apr 16, 2007 | 05:47 PM
sLoW'n'StEaDy's Avatar
you could probably make some sort of "mount" for the turbo. or jus do some bracing. I am either gonna run a T-61 or a GT-42 (clones, not actual garretss, im too poor) I am gonna use that same bend (well two of them) and figure out a way to make a mount or support as i was told you should never rely on the manifold to hold the weight of a turbo.
Old Apr 16, 2007 | 09:01 PM
CMonakar's Avatar
rebreaking things
I built a 42R manifold for my 3 rotor. The turbo weighs over 40lbs. I wouldn't even think about supporting it with the manifold runners. I suspended mine from the water pump housing using a chrome alloy bracket that looks kind of like a suspension A-arm.
Old Apr 18, 2007 | 11:02 AM
zbrown's Avatar
here is what i did for my 42
and my manifold is made out of sched 10 SS.... which is much thicker than thin wall 16 ga....... 16 ga un supported would just fall over once operating i would think
the only way i would do a manifold in which the runners support full turbo weight is if the runners were of sched 40 pipe
this is on an a rew engine in my fc... and i could stand on the brace before any of the manifold was done
the 42 is a 45lb turbo.... which is considerable
Old Apr 18, 2007 | 11:07 AM
zbrown's Avatar
ha... great minds must think alike, i am picturing yours like mine??
Andrew7dg
Aug 6, 2017 01:41 PM
eplusz
15
Oct 7, 2015 04:04 PM
