Microtech after start enrichment question.. please help
Old Apr 15, 2007 | 09:44 PM
dean23's Avatar
pwned
my car wont hold idle on its own while the engine warms up. instead on sitting in the seat and holding the rpms up, can i adjust the af_ste to a high value (currently at 10% till 5hg)? and what would you guys recommend rasing it to? woudl i need to change the hg setting, or is that a constant? or will changing it cause the af_Ste to run the injectors longer?
Old Apr 16, 2007 | 09:00 AM
Aaron Cake's Avatar
Engine, Not Motor
You need to adjust the coolant correction, not the AF_STE. But you can only do this after you have the rest of your map tuned.
Old Apr 16, 2007 | 09:43 PM
dean23's Avatar
pwned
the maps already tuned... its just when its cold it doenst liek to idle well until the engine gets warm. also i think theres det. at full boost (~12 psi). should i retard the timing, or would that not work...
Old Apr 17, 2007 | 12:56 PM
Aaron Cake's Avatar
Engine, Not Motor
Don't drive to 12PSI if you are getting detonation unless you want to rebuild the engine. Figure out why you are detonating. What is your timing at 12PSI? A/F ratio?
If the car won't idle until it's warm, then you need to adjust the coolant correction map.
Old Apr 19, 2007 | 04:14 AM
RotaryEvolution's Avatar
Sharp Claws
your tuner sucks.... seriously.
find someone who knows what they are doing with your EMS and who knows how to tune a rotary.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
