Shifting into 1st and 2nd is taking more effort
Old Mar 21, 2002 | 11:39 PM
FEDREX's Avatar
"Just Looking".......
Lately, I've noticed it's more difficult to get into 1st or 2nd gear. There's a sound when I listen under the car that makes a random sound similar to a part of the exhaust near the front of the transmission making a light clunk against something. Or something in the front internal part of the tranny that sounds like it interrupts idle every few couple of seconds or so. My rpm at idle varies occasionally about 75-100 rpm - this coincides with the sound under the car.
Driving around is fine but 2nd gear seems to take more time and effort than it used to...3rd and up drop right in with no problem. First is just plain stiffer to get into gear.
(I had my clutch done about 2 years ago and have probably put 50k on it)
Old Mar 22, 2002 | 07:58 AM
Josepi's Avatar
Despise Enmity
How many miles on the tranny? Who installed the clutch? Change tranny fluid lately? What all was replaced on the clutch redo?
Old Mar 22, 2002 | 09:27 AM
pd_day's Avatar
Spoolin'
I got the same problem.
I looked at my hydrolics and found that my clutch slave cylinder is leaking. I am getting it replaced as we speak. I'll let you know.
However, RETed suggest it might be a bad pilot bearing. Let's cross our fingers that it's not!
Old Mar 22, 2002 | 10:46 AM
FEDREX's Avatar
Originally posted by Josepi
[B]How many miles on the tranny? Who installed the clutch? Change tranny fluid lately? What all was replaced on the clutch redo?
110K
A shop I trust.
Redline MT-90 less than 25K miles ago.
ACT HD pressure plate, SR 9.5lb. flywheel, FD clutch disc, pilot/throwout bearing, (and I think some other bearing)
Old Mar 22, 2002 | 12:38 PM
turbotwista's Avatar
Crossing fingers for ya
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
mustanghammer
Race Car Tech
28
Nov 22, 2015 07:10 AM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
