Anyone use the oil temperature and pressure adapter from Racing Beat?
Old Mar 21, 2002 | 06:47 AM
tmak26b's Avatar
Anyone use the oil temperature and pressure adapter from Racing Beat, part #11802? I am wondering how hard they are to install, also how is the result from that adapter? I assume really good? I am looking to get one, it seems like you can keep teh stock pressure sender in place if you get this right? Let me know,t hanks
Old Mar 21, 2002 | 08:06 AM
Wankel7's Avatar
Haven't we ALL heard this
I bought it for my '91 TII. If you look at my thread, "Wrapped downpipe and engine progress" you can see it where the oil filter is. I have installed it with the engine out of the car. It was a piece of a cake Not hard but just some work with the engine in place. I made one mistake when I installed it. I guess I used to much torque and the stud broke. So I used a bolt with an allen head. I cut it the right length and screwed it in where the stud was supposed to go. Seals fine.
I put in an Autometer Oil pressure and temp. sending unit. I am happy with it. You can retain the stock sender.
James
Old Mar 21, 2002 | 10:41 AM
Silkworm's Avatar
Has been.. hangin' around
Ditto.. Although if you do it in the car, install the block, then the senders.. That oil pressure sender from autometer will get in the way if you try to install it first.
PaulC
Old Mar 21, 2002 | 10:45 AM
tmak26b's Avatar
So the adapter block goes below the oil filter without blocking anything? How hard is it to install?
Old Mar 21, 2002 | 10:52 AM
Silkworm's Avatar
Two 10mm nuts hold the oil filter "thingie" to the engine block, from the bottom. remove those, and remove the oil filter "thingie"
Screw the new studs into the oil filter block, install new o-rings, and sandwich the guage block between the oil filter neck and the block. tighten.
Easy . Just kinda tricky to get in there with a 10mm wrench.
PaulC
Old Mar 21, 2002 | 10:53 AM
fc3s.org's Avatar
OG
Piece of cake. Takes longer to run the lines to the cockpit than it does to install the block It even comes with new o-rings. Nice piece. I have it on both of my RX-7's
Old Mar 21, 2002 | 11:04 AM
tmak26b's Avatar
thanks for the info, i gues it is a doable job. i will orderd it this week
Old Mar 21, 2002 | 12:26 PM
Max7's Avatar
Admitted Sevenaholic
Works great and pretty simple installation
Lager pic - http://my7.rx-7.org/Paul/images/Paul...-Feb200222.jpg
Old Mar 21, 2002 | 06:06 PM
tmak26b's Avatar
thanks, i will order that soon. Now my job is to find the god damn water temp sender, i kept looking from the top, i cant find it. Do you see it better from the bottom?
thecody59
40
Aug 23, 2015 06:41 PM
GrossPolluter
Aug 22, 2015 11:23 PM
