West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
question about smog and turbo
Old Mar 27, 2007 | 09:30 PM
Rx7 922's Avatar
i was wondering if you would pass smog on a fd with a bnr stage 3 turbo, with all the stock components?
Old Mar 27, 2007 | 10:38 PM
Kingsfan's Avatar
CLIPPERNATION
i wouldn't, but that's just me
Old Mar 27, 2007 | 10:41 PM
sk8rwillow07's Avatar
Caterpillar = Lil Red
No
Old Mar 27, 2007 | 10:42 PM
Rx7 922's Avatar
coo thanks guys, another question, if you install a pfc would you be able to switch it out and put in your stock ecu in time for the smog test?
Old Mar 27, 2007 | 11:13 PM
slo's Avatar
slo
registered user
yes you can pass smog with a bnr stage 3 turbo, the smog test doesn't have the engine accelerate fast enough to get much into boost. The BNR turbos will not fail the visual inspection.
Old Mar 27, 2007 | 11:14 PM
GoRacer's Avatar
Speed Mach Go Go Go
what? ovcourse you would. how would rebuilt oem twin turbos (with larger wheels) affect your smog? they would still be considered stock twin turbos. Even with a Pettit or M2 ECU, I still don't see a problem if everything else remains stock. You could even do a M2 style intake box which is legal since it retains all the stock lines. If no one will pass you then you can go to a referee for a sticker then no tech can fail you for not knowing better.
Old Mar 27, 2007 | 11:17 PM
Rx7 922's Avatar
thanks go racer
Old Mar 28, 2007 | 02:21 AM
DJDINO's Avatar
CEO of Belligerents INC.
Dude...you need to worry about smog when you have a great member like WackyRacer around. He could help you pass smog. No paper work needed either. Just PM him.
Old Mar 28, 2007 | 03:30 AM
pshaw118's Avatar
Assassin of feudal Chinoy
and have the astroglide handy. You'll need it.
Old Mar 28, 2007 | 01:50 PM
Rx7 922's Avatar
so you will pass with the bnr stage 3 turbos? how about if you take out the pfc and put back your stock ecu?
Old Mar 28, 2007 | 03:05 PM
Siraniko's Avatar
RX for fun
For a shiny polished part, PM DJDIno or Goofyrotor. I highly recommend them.
Old Mar 29, 2007 | 12:25 AM
GOOFYROTOR's Avatar
cams pistons valves
for a goooood cleaning job, pm Wackyracer for an excellent slurp.
....................................number 1 customer at seven-eleven.
smikels
Rtek Forum
May 12, 2016 12:34 AM
Machupicchu
Aug 17, 2015 08:27 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
