Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Engine's that will fit?
Old Mar 26, 2007 | 06:22 PM
Carthik's Avatar
Are there any engines that will bolt right into an FB and its transmission without much work? I would assume from mazda? or maybe not...
Thanks,
Carthik
Old Mar 26, 2007 | 06:34 PM
85 FB's Avatar
7-less
Are you talking about using the FB's stock transmission or a replacement engine's transmission?
I've seen photos of people dumping in Chevy 350's and Nissan 240SX motors. Altho, this just takes away the entire being that is the RX-7.
Old Mar 26, 2007 | 07:43 PM
Carthik's Avatar
I know, but im thinking of it just temperarily. And Im talking about using the stock tranny and bolting up an engine that will just fit, any engines exist? I was thinking the MX3 engine?
Carthik
Old Mar 26, 2007 | 08:05 PM
Arthur Dent's Avatar
42
The short answer is no. The closest engine to bolting up would be the 2.0L/2.2L engine out of a B2000/B2200 truck. Would bolt up to the transmission with the truck bell housing. Engine mounts would be different though. Its not a powerful engine though. A turbo version sits in the 626 so I suppose one could use that with a B2000 bellhousing but not sure what the point would be.
Lots of V8 swaps - search for Granny's speed shop for kits.
Old Mar 26, 2007 | 08:34 PM
Boswoj's Avatar
Think about the nature of rotary and piston engines. The eccentric shaft on a rotary is in the middle of the motor, while the crank of most piston motors are at the bottom. There are lots of packaging issues that make the conversion of a rotary to anything else a fair amount of work. It might be something that someone wanted to do for their own reasons and I have no problem with that, but it is a pretty unlikely thing to do temporarily. If you make a swap, it is likely the car will NEVER be changed back. Except for my car, of course, and that is a whole story in itself.
Old Mar 26, 2007 | 08:45 PM
steve84GS TII's Avatar
FB+FC=F-ME
Rotary engines fit rotary trannies.....its as simple as that.
Engine architecture aside,the bellhousing pattern is unique to rotaries alone.
Just about any engine will slip into a 1st gen's bay,there is lots of room.Few will match the rotaries compactness and center of gravity though.
I think your missing the main factor.....and its not that an RX-7 MUST have a rotary in order to have a soul.... (to each their own,were all car people here)
The main thing to consider is this.....if you,yourself can plan and execute a non-rotary ENGINE transplant into an RX-7,then installing the TRANNY that is made for that engine,should be simple by comparison.
fidelity101
13
Aug 31, 2015 07:47 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
rx7jocke
Aug 15, 2015 03:36 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
