Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
effects of timing changes on a rotary
Old Mar 20, 2002 | 04:21 PM
grampa's Avatar
Question effects of timing changes on a rotary
Can anyone give some references to documentation on the effects of timing changes for rotaries?
Solid data in relation to turbo charged applications is a plus.
Heresey is of no use to me.
Old Mar 22, 2002 | 04:06 AM
1000HP20B's Avatar
What type of engine are you talking about..FD or FC turbo.
Generally as a rule 18 degrees total ignition timing up to 15 psi with 95 octane fuel is O.K if you have good air temps and good mixtures. 18 degrees total versus 12 degrees total under boost is generally worth 8 rw KW or 16 engine HP on a standard FC turbo.
Old Mar 27, 2002 | 07:58 PM
waynespeed's Avatar
Is this with firing the leading and trailing plugs together (no split)?
Old Apr 3, 2002 | 10:46 PM
RETed's Avatar
There are several FSAE papers out on this subject.&nbsp I dunno where to get them, but the FSAE website might be a start.
We have the Cosmo internal manual from Mazda.&nbsp It has the stock ignition maps in it.&nbsp NO, I'm not giving these away.
-Ted
Old Apr 4, 2002 | 02:24 PM
TailHappy's Avatar
Addicted to Track
May not be what you're looking for, but check out the 3rd Gen Archives. There's a post with a title along the lines of "Help me learn to tune" that has some hard numbers on timing.
11
Nov 9, 2015 01:15 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
20B Forum
Aug 19, 2015 01:47 PM
