Help! Pics Of 245/45/r17 On An Fd With Stock Height Needed Please!!!
Old Mar 22, 2007 | 07:15 PM
eightsixlife's Avatar
eightsixlife
Hi I Have Wheels But Am Contemplating To Buy Smaller Tires, I Cant Try Them On As Of Now Because My Car Is In The Body Shop And One Of The Locks Are Pretty Much Stripped On The Wheels, So Thats Why Im Asking For Pics, Anyone?
Thanks, Robert...
Old Mar 22, 2007 | 11:04 PM
eightsixlife
bump...
Old Mar 23, 2007 | 12:51 AM
eightsixlife
nightly bump?
Old Mar 23, 2007 | 01:37 AM
SpeedKing's Avatar
Power Trippin'
I don't think anyone is running 245/45-17 because it is the wrong size! 225/45-17 or 235/45-17 is closer to stock diameter.
Old Mar 23, 2007 | 03:19 AM
rynberg's Avatar
The correct size is 245/40, not 245/45 17.
Old Mar 23, 2007 | 10:43 AM
eightsixlife
hey guys, i understand that, the reason why im asking is because i have a set of mustang gt wheels i want to put on, and thats the size that they are... also what do you mean wrong size? is there some reason that wont fit right? any help?
thanks, robert...
Old Mar 23, 2007 | 10:48 AM
rynberg's Avatar
You need to edumacate yourself....do you think tires are the same diameter on all cars? Go to www.tirerack.com and read the wheel and tire tech sections. There are also TONS of fitment threads in this forum.
1. 245/40 17 maintains the stock diameter, 245/45 17 will be 1-inch bigger in diameter than stock, which is great if you are going off-roading....
2. Mustang wheels are HEAVY and won't fit an FD anyway, the offset is too low
Old Mar 23, 2007 | 10:55 AM
eightsixlife
yes i admit i dont know too much about offsets and what not... and no, i dont think tires are all the same diameter on cars... well i am planning on installing racingbeat lowering springs, was planning on buying smaller tires, but i was just trying to see if i can get away with it when installing the springs... also, the mustang wheels do fit, do you mean they wont fit propely? like i said i dont know too much about offsets, but i think i read somewhere that the offsets on supra/rx7/mustang were all that same, +50mm? i forgot... any help?
Old Mar 23, 2007 | 11:08 AM
rynberg's Avatar
I would avoid the Racing Beat springs....they lower the car too far without increasing spring rate (lots of rubbing problems).
Mustang wheels are NOT +50, more like +30 IIRC, but which Mustang wheel are you talking about? There are different diameters and widths.
Old Mar 23, 2007 | 11:19 AM
eightsixlife
oh sorry, i forgot the year, they are off an 02 mustang GT...
they are on this website, the first 4...
http://shop.wheelsrims.net/search.ht...&part_subtype=
i put them on my car, but the sidwalls were a bit too big... with the lowering springs do you think thats a problem?
Old Mar 23, 2007 | 12:07 PM
Josh18_2k's Avatar
geez.. mustang wheels are not heavy. 17x8 GT wheels weigh 17lbs.
and the offset is indeed +30.
Old Mar 23, 2007 | 12:13 PM
eightsixlife
will they fit on my car corrrectly? they have 245/45/17 on them, how will that work?
Old Mar 23, 2007 | 12:16 PM
rynberg's Avatar
1. Like I said above, the tires are 1" too tall.
2. Well, yeah, they bolt on to the car, but they are not a proper fitment. The offset is too low, resulting in changes in scrub radius, increased wear on wheel bearings, and lunched fenders.
My advice, sell the wheels and get proper fitting ones with correct tire sizes.
Old Mar 23, 2007 | 12:18 PM
Josh18_2k's Avatar
just wait till you can get to your car, then put em on and see how it looks. to check clearance (if its not obvious) you can disconnect the shock, then jack the wheel up into the car. if the tires hits the fenders, ditch em. if they clear, keep em.
i dont think you're gonna get a strait answer on here. i doubt anyone actually tried the mustang gt wheels on an fd.
Old Mar 23, 2007 | 12:25 PM
rynberg's Avatar
I don't have to try out Mustang GT wheel to know a +30 offset wheel is not a proper fit!
Old Mar 23, 2007 | 12:30 PM
eightsixlife
ok rynberg, so buying smaller tires wouldnt really help? and josh i understand what your saying, i just don want to hit a dip while turning and be forced to buy a new fender... so what are the correct wheel sizes? and are they or not the same offset as supras? thanks
Old Mar 23, 2007 | 01:02 PM
rynberg's Avatar
With a stock suspension, you could probably get away with running those wheels (with proper size tires) without catching the fender lips, but you'll still have the other issues I described above. Lowering the car will throw that out the window and fender rolling will be required.
Stock FD offset is +50....don't worry about what fits other cars, once you know offsets that fit, you can shop smarter. If you spent a little time here researching proper FD fitment, you would quickly learn what fits. There is even a sticky thread showing minimum offsets for wheels (minimum on stock suspension, not ideal, and not including lowering).
generally:
front
8-8.5" wide: +40 to +50 offset
9" wide: +43 to +50 offset*
9.5" wide: +47 to +50 offset*
10" wide: +50 offset and aftermarket coilovers*
*fender rolling recommended
rear
as fronts, but you can get away with 8-9mm less offset (not that it's a good idea, but it will fit)
TIRES: should be close to the stock diameter of 25", typical sizes would be:
225/50 16
245/45 16
225/45 17
235/45 17
245/40 17
255/40 17
265/40 17
275/40 17 (recommend rear only)
225/40 18
235/40 18
245/35 18
255/35 18
265/35 18
275/35 18 (recommend rear only)
285/30 18
295/30 18 (recommend rear only)
Old Mar 23, 2007 | 01:11 PM
eightsixlife
ok rynberg thanks, idk too much about how offsets and fittings, for ex...
front
this means anything between 40-50 will fit right?
so i think if i get those springs, i should just sell the wheels and get some better fitting ones?
also do the s5 NA wheels fit on an fd? i have a set of those and they are also 5 lug, but not sure if they'll fit...
i think il just sell the gt wheels, dont have enough money for tires and its not worth it since im going to lower the car... thanks...
Old Mar 23, 2007 | 02:18 PM
rynberg's Avatar
NA wheels are a max of what, 16x7? Why would you want to put smaller wheels on? Don't you still have the stock FD wheels?
Old Mar 23, 2007 | 02:51 PM
Roen's Avatar
The Silent but Deadly Mod
NA wheels are max 15 x 6.5 on the vert. The common coupe wheel is 15 x 6.
The 16x7 GTUs wheels are the same as the 16x7 Turbo II wheels.
Old Mar 23, 2007 | 02:52 PM
br555's Avatar
Just FYI - The original Bullitt wheels are 22mm but the '05+ GT wheels have a 42mm offset. Problem is they look like *** - The spokes are flattened out and the lip is virtually non-existent...
*edit* I misspelled Bullitt, oh the shame!
Old Mar 23, 2007 | 03:07 PM
eightsixlife
lol, no br55 not those wheels, the 5 spoke 02 GT wheels are what i have, without the center cap... and rynberg, i forgot about the width, but no i dont have stock fd wheels, it didnt come with them... it came with some ford probe wheels that are also 5 spoke, but with that skillsaw look? do you know what i mean? those kind of sharkfin spokes, anyway, its either those, the GTs or idk man, i dont have the stock ones, and we have some nice 5 spoke FC wheels, thats why i was asking... thanks...
Old Mar 23, 2007 | 03:29 PM
rynberg's Avatar
I happen to be selling my stock wheels..... the tires on them still have tread but they've been sitting around a couple of years so probably don't have the greatest grip anymore.
The cheapest solution would be to buy some stock wheels with new(ish) tires on them. I feel obliged to point out if you can't afford tires, I predict a painful FD ownership experience.
Old Mar 23, 2007 | 03:39 PM
eightsixlife
man i would be interested in your wheels, but for the price you would want+shipping i should just buy some aftermarket wheels... anyhoo, yea im just jobless right now, thats why, but when i do itll be cool... btw do you think 245/40 would be cool on the GT wheels for my car?
man i would love some mesh wheels... drool*
Old Mar 23, 2007 | 04:18 PM
rynberg's Avatar
Well, you would be selling your Mustang wheels/tires.....
David Hayes
13
Sep 5, 2022 12:45 PM
