Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
HKS-FCON installed - now get stumbling
Old Mar 20, 2002 | 10:22 AM
Toadman's Avatar
Nomad Mod
The FCON smoothed out the entire powerband and removed the 3k hesitation, but now it stumbles twice at primary-to-secondary transition. I mean, the whole car's balance gets upset, and it doesn't feel/sound like fuel cut. Boost pattern is a good 12-8-10, and the internal adjustment screw(calibrated 1-9 with 9 being full rich) is set at 3 for my engine mods below. Any suggestions? HKS is no help in suggesting proper settings, and I don't have an AF or EGT guage yet. I do get a lot of cold-start backfiring and popping between gears, but I think that is normal richness. I'm pretty sketchy about running lean, of course. Any suggestions on what setting I should base-line with? Anyone have a spec sheet?
93 Base Leather
HKS Downpipe
RB cold duct/OEM filter
Borla Cat-back
HKS PFC-FCON
Old Mar 20, 2002 | 11:12 PM
Toadman's Avatar
Nomad Mod
Hey Toadman, check your silicone vacuum lines going from the sensor to the IM. Mine cut itself on that really sharp metallic ABS shield from vibration.
Old Mar 20, 2002 | 11:20 PM
Toadman's Avatar
Nomad Mod
Hey thanks Toady, that's what it was! I re-routed a new vacuum hose to the IM and zip-tied it. No more boost leaks at 12 psi. You rock dude...
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Enzo1944
Sep 6, 2015 08:57 AM
