what do i do with air pump hose with mid pipe?
Old Mar 20, 2002 | 07:34 AM
slopoke's Avatar
i am getting my mid pipe on today and was wondering what to do with the air pump hose and the air pump. should i just plug the hose by the cat, or is it bad for it? i would like to still leave it operational incase i have to put it back on for emmisions test and stuff. thanks for all the help, scott
Old Mar 20, 2002 | 08:05 AM
lerch32's Avatar
I had left it unplugged right below the tranny. The air pump will still blow air out that line, so I did not want to take the chance of riuning the pump.
Old Mar 20, 2002 | 08:08 AM
ttpowerd's Avatar
HARRRRRRRRR
heck ya...I was right!! He pmed me and I told him the same thing.
My question is: should you cover it will a mesh type material so crap does not get in there saying it does not blow while you are driving, just at stops?
Thanks
Old Mar 20, 2002 | 08:44 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Just take that crap off!You dont even need the smog pump.You can pass emmisions without it.
Old Mar 20, 2002 | 09:13 AM
ttpowerd's Avatar
HARRRRRRRRR
how...you need a cat to pass don't you?
Old Mar 20, 2002 | 11:59 AM
Import Convert's Avatar
Cat will help. That doesn't mean you need the air pump.
Old Mar 20, 2002 | 12:02 PM
ttpowerd's Avatar
HARRRRRRRRR
oooooh, but won't you clog the cat if you are not getting air to it?
Old Mar 20, 2002 | 01:10 PM
Just spoke with Dave at kdr about this. Without the airpump, the cat will clog in about a year, give or take. It won't happen overnight, but still not a good idea to run a cat (high flow or otherwise) without the airpump.
And just for the record (I'm sure this is a little known fact ) you do indeed need at least a high flow to pass emissions. Running your FD with an open exhaust is about the worst thing for the environment possible
Old Mar 20, 2002 | 03:00 PM
skotx's Avatar
Registered Abuser
Am I making this up or have I seen a midpipe that had a little flange made to bolt up the airpump line? That would be handy as you wouldn't have to tie-wrap it ghetto-style like I did.
Old Mar 20, 2002 | 04:16 PM
Want2race's Avatar
Bigger and better things
you can remove the airpump and thehoses assosiated with it!~
You may/will need a resistor to keep a normal idle though!
Old Mar 20, 2002 | 05:34 PM
slopoke's Avatar
thanks for all the replies. i guess i will just leave it hanging there. thanks, scott
Old Mar 20, 2002 | 05:38 PM
ttpowerd's Avatar
HARRRRRRRRR
Scott, There is the metal pipe that leads to the hose. Take the hose off and nothing will be hanging + you will still have it attached for emissions.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
