80mm hi-flow cat
Old Mar 19, 2007 | 05:49 PM
Phantomkid's Avatar
80mm hi-flow cat
So im moving to california in a little under a month and as of now my exhaust set up is the corksport 80mm turbo back full system. only one problem... i have no cat on there at all, here in arizona they dont care to much about emission but over there in cali i heard there crazy. so i figure its a good idea to get at least a cat for the car, it will be registered in arizona. My problem is ive been searching and looking through the forums for a 80mm free flow cat if anyone is fimilar with the corksport exhaust theres a midpipe section thats about 2ft long that i can probably take to a shop and have them chop it up and weld in a cat to those flanges. but im having a big problem finding a hi flow cat of this size 80mm/ 3 1/8in. I was wondering if anyone else has installed a hi-flow cat on there corksport system or if anyone konws where to get 80mm hi-flow cats.
Old Mar 19, 2007 | 06:11 PM
Brody8877's Avatar
#FakeCarEnthusaist
try a Bonez 3" Highflow cat. from rx7.com
Old Mar 20, 2007 | 04:58 PM
jgrts20's Avatar
Who are you?
do you have an aftermarket header, if so you will not pass emmisions. I will be movin' there in july and have already did research on this subject. Exhaust has to be OEM or you wont even pass the visaul part of the test. Air intake has to be OEM or have a Cali expection on it. Sorry good luck though!
Old Mar 20, 2007 | 05:00 PM
jgrts20's Avatar
Who are you?
http://www.racingbeat.com/emissions.htm
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
start here!
Old Mar 21, 2007 | 11:03 PM
Phantomkid's Avatar
i understand i wont pass emissions, that is not my worry. the vehicle and where i can claim residence is in mohave county, where they do a half *** visual inspection. my brothers 7 passed and it has no cats and at school buts out around 3k in hcs( def not legal). But this is not my worry. I can pass emissions and get it registered in mohave county. My worry is if i get pulled over in cali and i dont have a cat thats a 15000 fine and i know cali is crazy with all that, so i just want a cat so i dont have to worry. i will only be in cali for 4 months but dont want to risk it. Brody thanks i looked at the site they only go to 3in unfortunitly i have a 3 1/8 system.. thanks for the help guys and if anyone knows where to find a 3 1/8in hi flow cat alone that would be greatly appreciated..thanks
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
