Sponsored by: CARiD
Will an 88 motor work in my 90?
Old Mar 19, 2002 | 11:50 PM
90GXL's Avatar
Newbie
Hi all,
I've got a 90 GXL auto with a blow seal on the rear rotor. I'm looking at buying an 88 motor. I was told that I would need to change out the front covers for them to interchange, but that's all. Is it really that simple? Is there anything else that would need to be done? Are these 2 engines identical other than that?
Thanks,
E
Old Mar 20, 2002 | 12:14 PM
RacerXtreme7's Avatar
NASA geek
yes and no, 88 motor will work if........ you use the block only, you get the appropriet rear counter weight, and you change the front cover. Use ALL you 90 parts (entire intake, front cover, OMP, water paump, etc.) The 86-89 motors have lower compression and HEAVIER rotors there for you need a different rear counter weight. You will experience a performance loss due to heavier and lower compression, but it will work.
Old Mar 20, 2002 | 12:16 PM
NASA geek
86 -88 motors, oops I didnt mean 86-89
Old Mar 20, 2002 | 05:05 PM
90GXL's Avatar
Newbie
Eck! I don't want anything that isn't the same as what's in there. Anyone else know about this? Heavier rotors and lower compression? Doesn't sound good to me.
Thanks all
cristoDathird
28
May 30, 2019 08:47 PM
Heedlessone
288
Sep 16, 2018 07:22 PM
sYnth.
Aug 19, 2015 06:27 PM
andyvideopro
Aug 11, 2015 09:16 PM
