Thinking of Painting Stock Rims
Old Mar 18, 2007 | 07:17 PM
87_rocket's Avatar
gotNOS?
Usually not a great idea, but here is what I was thinking, let me know what you guys think of it:
My car right now
What it could look like
I would go for a gloss black and polished lip, which i think gives the car a more aggressive look. Has anyone done this to their phone dials?
Old Mar 18, 2007 | 07:34 PM
Syncro's Avatar
Buildup Thread Encourager
I personally think it looks like ***.
Gloss black and polished lip will definitely look better (less ghetto) than flat black.
It's your car, do with it what YOU think is coolest
Old Mar 18, 2007 | 07:42 PM
RX-7Tunner86's Avatar
it looks alright
Old Mar 18, 2007 | 07:46 PM
BLKTOPTRVL's Avatar
I like it.
Old Mar 18, 2007 | 07:54 PM
Twofer's Avatar
I am the stig.
Graphite gray FTW.
https://www.rx7club.com/showpost.php...3&postcount=12
Originally Posted by Twofer
I recently painted my phone dials, and I'm really happy I did. There was always something about my car that looked odd. (Aside from the previous owner's poorly repaired dents and body damage.) I'd look at other FC's and think that they looked a lot slicker, but really couldn't figure out what it was. After painting my phone dials Graphite Gray, I realized the silver-ish rims were making the car look taller. My friends commented that it makes the phone dials look "less old".
I originally went with black, but ran low after 2 wheels. I went to the local auto parts shops and they were sold out of Black, so I took a chance on Graphite Gray. (Dupicolor wheel paint.) With one side of my car on black rims, and the other on graphite, it gave me a chance to compare them. (Also, I didn't think anyone else would notice they were different colors since you only see on side of the car at the time.) The next week I stripped the black wheels and went Graphite all around.
For prep work, I removed the old clear coat / paint with KleenStrip Aircraft Remover from Autozone, which works great as long as you slather it on like BBQ sauce. (Use chem gloves and glasses, it burns like a mother.) After that, rough sand with 100 grit, then smooth with 220 grit, then one coat of primer, and one coat of paint. (As heavy as possible without getting runs.) I did the black rims without primer and following the directions on the can and it didn't come out as well.
Before:
After:
Original w/ flaking clear coat:
Graphite vs Black:
turbo10th's Avatar
Nvm forgot you had 4 lug was going to say get some turbo 2 rims.
Old Mar 18, 2007 | 07:56 PM
turbo10th's Avatar
Graphite dont look too bad though
Old Mar 18, 2007 | 08:01 PM
NCross's Avatar
I have a rotary addiction
get some s13 bolgna slicers. 15x6.5, uber easy to find, and 240 people are practically giving them away. z31 turbo wheels would look better too. s14 4 lugger "mesh" if you can find em.
Old Mar 18, 2007 | 08:24 PM
87_rocket's Avatar
gotNOS?
well i would like to use my current tires for a while. this is just temporary until my tires wear out and i have enough money (hopefully) for a new set of aftermarket rims and tires. here are some more pictures of what it might look like:
fixed*
Old Mar 18, 2007 | 10:24 PM
Twofer's Avatar
I am the stig.
Originally Posted by 87_rocket
I was admiring your phone dial paint job, and since I have been thinking of doing something similar I figured I'd ask you how difficult it was. Also, how long did the project take for you? I would really like to finish the project in one weekend, do you think that it is feasible? Thanks.
I believe it took me about 4 hours x 2 days with my brother doing the painting and me doing the prep work. The nasty clear coat that was on there took most of the time to remove. So yeah, weekend I'd say.
Go over the wheels really good with 100 grit sand paper to rough up the surface, then clean it off with soap and water. Mask it off with masking tape and newspaper strips, maybe 6 in wide and a foot long, in a pattern around the wheel. Then do a coat of automotive primer, let that dry, then do a medium - heavy coat of color. We only did one color coat, and it's held up fine. Another color coat would be ideal. I don't remember how many cans of paint we went through, I think it was 1 or 2 good sized cans. (Buy more than you think you need and return the unused cans after you're finished, so they don't run out like in my case.)
Note: The Aircraft Remover needs to be pressure washed off, which was part of my problem. (And I imagine it'll dissolve rubber too, so be careful. And don't get it on your skin, it burns like a ****.)
Old Mar 19, 2007 | 01:10 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
black is uglie.
grey looks better.
Old Mar 19, 2007 | 01:21 AM
MrFC3S's Avatar
ROTARD FOR LIFE!!!
just a thought, have you considered swaping to the more comon better looking and 4piston 5lug swap?
a set of painted Coupe or 89-91 GTU,GXL wheels look good and fit great. not to mention iirc they are 16x7s, so there also wider...
4lug meshies ftw
cristoDathird
28
May 30, 2019 08:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
RCCAZ 1
Aug 11, 2015 07:05 PM
