Track Tires most Durable?
Old Mar 18, 2007 | 01:48 PM
Mid_KnightFD's Avatar
What tire will you get the most out of? I will be doing some track days and I want, for now, something that I can get a few days of running on. Later I will go with a Hoosier or a Kumho. I was thinking the AO48. I do not want a street tire as this will be a dedicated track car. I need something I can go practice on and not have to go buy tires after one weekend. Thanks
Old Mar 18, 2007 | 03:05 PM
Mahjik's Avatar
Mr. Links
What sizes will you be using? The Victoracers have good wear.
Old Mar 18, 2007 | 03:35 PM
bean13's Avatar
I have heard toyos can wear and wear but have no first hand experience on that.
Old Mar 18, 2007 | 04:50 PM
Size 315 or 305 18"R 275 or 285 18"F on CCW wheels. I am going as wide as I can. I will have wide fenders, Pettit rear and shine auto Spec b fronts. I am looking for a good practice tire basically. Even a hard compound slick would be ok as long as it last longer than one weekend. This will be a time attack car.
Old Mar 18, 2007 | 05:11 PM
Mahjik's Avatar
Mr. Links
I don't believe Victoracers come in 18's, so that leaves that tire out.
Old Mar 18, 2007 | 05:12 PM
darkslide750's Avatar
I'm running RA-1's and they seem good for a long time. I have 9 full track days on mine and they are still sticking. I flipped them on the wheels 2 track days ago. I also ran the YOKO AO48's and they had a lower treadwear but somehow had less grip. I ran 3 days on them and they showed little wear. 275/40/17 on all corners btw.
Old Mar 18, 2007 | 06:06 PM
When you say 9 full track days, what would that be in total mileage? So the AO48's actually would probably last longer but with less grip than the RA-1's.
Old Mar 18, 2007 | 06:54 PM
photopaintball's Avatar
toyos
Old Mar 18, 2007 | 09:17 PM
rynberg's Avatar
You are VERY limited by brands in those tire sizes....pretty much the closest I see is:
Toyo RA-1: 275/35 18 front, 305/35 or 335/30 rear
slightly smaller:
Yoko A048 or Michelin Sport Cup: 265/35 18 front, 295/30 rear
Since these are "practice tires", I would go with the A048s based on price.
Final spec Hoosier R6: 275/35 18 front, 315/30 18 rear
Old Mar 18, 2007 | 09:36 PM
They make a 285/30/18 and a 315/30/18 AO48. Which is what I'm thinking of going with for practice.
Old Mar 19, 2007 | 10:10 AM
SPICcnmGT's Avatar
The Toyo's last and are probably the cheapest of the choices. Cheaper than Mich. anyway. I ran a full AutoX season last year with 4-5 track days and I plan on using them on the track this year until they are gone. I would say they will last 9-10 track days(new ones).
Old Mar 19, 2007 | 08:45 PM
ccanepa50's Avatar
Toyo RA1 is my vote, definitely shaved, to save money I use them for practice sessions then switch to hoosiers for qualify and race, if you heat cycle them and put them away for a week toyos will go on and on and on, a great tire to set the car up with, still drive well after many heat cycles, the switch to hoosier is not radical, just faster.....
(ITS 2nd gen) chuck
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
