Deals Gap Rotary Rally Archive Look here for threads from past Deals Gap Rotary Rally events.
Just tested some camera mounts..
Old Mar 11, 2007 | 10:44 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
I just tested one camera mount.. a smaller ones. More angles to come!
http://www.youtube.com/watch?v=qttlVUxLd18
Old Mar 12, 2007 | 08:37 AM
golferfreddie's Avatar
Start D@mn it!!
Looks good Phil!
Old Mar 12, 2007 | 09:24 AM
blwnrtr93's Avatar
putting it back together
looks like it works pretty good. are they suction cup mounts?
Old Mar 12, 2007 | 09:50 AM
PureMdMa's Avatar
1 of 203 94 White PEP's
Those look like they will work great Phil.
Old Mar 12, 2007 | 09:59 AM
Herblenny's Avatar
They are all suckion cup style.
Here are some pics.
One I tried was the one with the red cap. Its the smallest 4inch suction cup mount.
The BIG one is 10" mount with 175lb capacity.. I'm going to use that to strap the camera just in case it falls off the car.
All the mounts are plastic except for the big rectangular one.. so it shouldn't scratch the car.. hopefully!
Old Mar 12, 2007 | 08:59 PM
94RHDFD's Avatar
Formally 20b 3rd gen
Old Mar 13, 2007 | 10:38 AM
djmtsu's Avatar
DGRRX
Phil, you car supposed to Stop when you get to a stop sign.
jeez, where'd you learn to drive!
j/k
SHHhhhhh! LOL!
Old Mar 13, 2007 | 02:22 PM
Moejoe's Avatar
I like the roof mounted shot. I think I might give that a try. This is the mount I'll be workign with
http://chasecam.com/store/customer/p...cat=248&page=1
Old Mar 13, 2007 | 04:34 PM
Herblenny's Avatar
Becareful with those.. as you want one with a vacuum pump.
I did some research and the vacuum pump versions are more stable and less chance of popping loose.... especially outside of the car, when it falls, most likely your camera will not survive!. Inside, I think it should be fine.
Old Mar 13, 2007 | 04:54 PM
Moejoe's Avatar
Thanks Phil. I'm going to do some test runs with it mounted in front of the sunroof, with it open. If something should go wrong, I hope it falls in the car. I have a couple of camera's that I use. With one, I would be more worried about the mount. That will be the outside cam. I'm also looking at a lip stick cam to cover outside footage so I can keep the other mount in the car.
Jmolina0163
19
Sep 25, 2015 06:06 PM
Mps_hell
Sep 19, 2015 10:02 PM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
